Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd November 2009, 05:31 PM   #13421
RCruz is offline RCruz  Portugal
RCruz's Avatar
Yes... the Jensen caps are much more detailed than Nichicon or BHC.
I believe the detail is due to the better filtering capabilities... (4 pole act as a combination of chokes + cap)
But they can only be used in low current aplications because the signal flows inside them.
Old 2nd November 2009, 05:45 PM   #13422
Malefoda's Avatar
Send a message via MSN to Malefoda
Another subject to loose our sanity... FC are out of the race now?
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 2nd November 2009, 05:50 PM   #13423
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
I find FC, FM, FK to be great as smoothers, but don't like them after regs. I've always found them to really hurt treble performance anywhere near the load.
Cheers, Lee.
Old 2nd November 2009, 06:44 PM   #13424
Malefoda's Avatar
Try to mind where the "final caps setup" is, if I stand that a whole ZL/ZLH (ho wait my setup!) caps around is a 90% of the best and things with mixed caps mentioned above are in the final 10% with the extra ability to move the sound behaviour?
Where were the factory's brown'n old Elna? 15%?
Matthieu
(ahh these topics just drive me crazy like bypass stories... )
Old 2nd November 2009, 10:03 PM   #13425
Fidelity Audio's Avatar
Hehe the old what cap is best debate.
ZAs work best with low noise regs, I don't find any dryness this way.
Silmics are a little wooly for me, like Lee said they don't offer enought detail when used as local decoupling.
FC I always say great before regs (if larger caps like the Mundorf HC/SI cannot be fitted) but they are horrible as local decoupling caps. Very dry and bright.
SEPC oscons are the best cap i've used on digital circuits, not so good on dac analogue rails or opamps.
Muse are ok and do most things well but I tend not to use them as other caps offer more in their given area.
But of course these are my general opinions
Brent
Old 3rd November 2009, 05:59 PM   #13426
RCruz's Avatar
Now I am getting a very good idea about the BG alternatives.
Thank you all so much for the input.
Old 3rd November 2009, 06:01 PM   #13427
Glenn2 is offline Glenn2  United Kingdom
Glenn2's Avatar
Agree with most of that, although I like the Muses (particularly KZ) as op-amp bypass.
They give good solid bass, and they don't let the op-amps scream at you like some.
Ultra-low ESR caps are best avoided right on the outputs of LDO regs, but also LM317 etc. (Rubycon ZA for example). See Werner Ogiers' or Martin Clark's sites for details.
Old 3rd November 2009, 07:31 PM   #13428
Malefoda's Avatar
Hi Glenn,
what you are saying about the Muses KZ (where to source cheap?) seems very promising with AD8620! I keep that in mind... and compared to last sources of BG they are dirt cheap!
Old 3rd November 2009, 08:37 PM   #13429
UV101 is offline UV101  England
UV101's Avatar
Found this too!!!! Not sure I agree with it but it is another opinion.
Also looks like the test was not for local decouple.
High End Audio - Electrolytic capacitors
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 3rd November 2009, 09:41 PM   #13430
Glenn2's Avatar
Originally Posted by Malefoda View Post
Hi Glenn,
They work well with AD825x2 in my CD63.
These guys have them...
Nichicon KZ type electrolytic capacitors homepage
Note that on their component page, if you click on Black Gate you get Nichicon and if you click on Nichicon you get Black Gate.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Puffin
Page generated in 0.24120 seconds (59.15% PHP - 40.85% MySQL) with 11 queries
