Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th October 2009, 08:38 AM   #13331
Fidelity Audio's Avatar
Still no decoder!!!
That's not good
Brent
Old 19th October 2009, 09:07 AM   #13332
Malefoda's Avatar
Send a message via MSN to Malefoda
Hi Brent,
I got the second one Lee kindly sent me as the first is somewhere but home, and this one is not even making the disc motor running.
And I can't reach Ian who kindly offer to send me one, that's too sad :'(
Matthieu
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 19th October 2009, 09:12 AM   #13333
Oh bad luck.
I will try to get hold of Ian so he can contact you.
Brent
Old 19th October 2009, 09:30 AM   #13334
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Hi Matthieu, I am glad that arrived ages ago!
edit: I expect the fault is elsewhere, because I'm pretty sure that chip was fine. Sorry to hear you've had no joy.
Lee.
Old 19th October 2009, 09:36 AM   #13335
Not really. You do use the Grimboloid postal service
Brent
Old 19th October 2009, 09:39 AM   #13336
Thomo's Avatar
What you on about?
Lee.
Old 19th October 2009, 09:41 AM   #13337
Thomo's Avatar
I did another couple of mods this weekend: Silvered Mica caps on the servo and the HF Amp. I also swapped the 470uF Oscon SEPC on dac analog to 1000uF BG FK.
I got better, cleaner treble and a touch more separation and bass.
Cheers, Lee.
Old 19th October 2009, 11:29 AM   #13338
Malefoda's Avatar
Thanks Lee & Brent,
tray moves, mech moves up & down, radial is also OK, only the disc does not spin. Maybe too much damages around there, but I've check pins and target continuity and it's OK so I don't see any onther problem, I'll have another look later.
Matthieu
Old 19th October 2009, 11:50 AM   #13339
UV101 is offline UV101  England
UV101's Avatar
Hi Matthieu, sorry i've been illusive lately!
I do have a decoder chip that I can dig out. When I swapped mine, I found the problem was elsewhere. Check the whole signal path from the laser to the decoder using the service manual. My problem was in the HF amp area. The decoder chip will need the signal from the laser to spin the motor. Do you hear your laser focussing? Mine gave me very similar problems to you but it wasn't the decoder. I think there is a good chance that if Lee's decoder hasn't fixed the problem, mine won't either! I think you might need an oscilliscope to diagnose this problem! I think to be honest, i'd be on the look out for another player ready to start transplanting all the mods!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 19th October 2009, 12:08 PM   #13340
Thomo's Avatar
Could it be clock signal too?
Lee.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
mikvous, hejira858
Page generated in 0.22849 seconds (64.79% PHP - 35.21% MySQL) with 11 queries
