Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 9th September 2009, 03:39 PM   #13151
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
LOL
That all depends on what you dvm display was ranging too. It may be 1.2V or 1.2mV or 12mV with a decimal thrown in for good measure lol etc. Do you not have a mV setting on your dvm or a range button?
Brent
Old 9th September 2009, 04:00 PM   #13152
padman is offline padman  United Kingdom
I'm gonna go for the 1.2mv as thats how it read which i'm guessing is low enough lol
Old 9th September 2009, 06:10 PM   #13153
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
is it harmfull to power only few 5Vs on the cdp without the other devices?
(my dedicated 5V TX and its 317 right on the player).
I've no way to check the decoder and others IC power right from the top, need the beast to be upside-down.
I'm exhausted, done nothing, just opened the lid, checked the room for the +/-10, touched the decoder analog reg and powered up the player. Since then it's dead silent even if I've checked all I can, continuity, resoldered some suspicious points... f!
Hope the decoder is not fried...
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 9th September 2009, 06:33 PM   #13154
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Originally Posted by padman View Post
Lastly can anyone point me in the direction of CY01 i cant find it
Cheers Ian
Hi Ian,
CY01 is located on the display board. If you 'upgrade' RY11 to an inductor, you may experience reduced sensitivity of the remote. The solution is to place a 10...47uF electrolytic cap across CY01.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 9th September 2009, 06:46 PM   #13155
Thanks Ray
RY11 is an inductor, i dont use the remote so guess i dont need the cap.
Ian
Old 9th September 2009, 06:54 PM   #13156
Ray,
As you're here, do you know reasons why a player will skip when cold?
It's done it since i got it.
Ian
Old 9th September 2009, 07:03 PM   #13157
The grease on the traverse is too thick and once warmed a few degrees it softens. Clean it off all the parts the laser moves over and apply a small amount of new thin grease.
Brent
Old 9th September 2009, 07:09 PM   #13158
6h5c's Avatar
It could be your laser is getting weak. As it heats up, the emission increases and the problem disappears. It could also be the discmotor is not rotating freely. If the shaft is a bit dirty, it may stick where it enters the motor when it is cold. When the disc starts to rotate, the sticky grease heats up and becomes more liquid.
If you have a scope nearby, you can check the HF signal and see if the amplitude if o.k.
The entry of the motor shaft can be lubricated with a tiny bit of WD40 for example.
A third possibility could be an IC that is rotten
Ray
Old 9th September 2009, 07:11 PM   #13159
6h5c's Avatar
You beat me Brent
Plenty of options to choose from, Ian
Old 9th September 2009, 07:14 PM   #13160
Don't like the sound of the 3rd 1
Think i cleaned the hard grease off but can't be sure i got all of it and didn't put new grease in
Gonna try to have some fun tomoz, lets see if the local hifi shops will let me put this up against som of thier wares. Lol
Marantz CD63 & CD67 mods listHide this!Advertise here!
Copyright ©1999-2017 diyAudio
