| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#13031 |
Hi simon i have played a few cds today and the 63 sounds good but i think the 67 was slightly more detailed and i think the midrange on the 67 was better on the 63 it sounds a little thin and blured. It seems to me that the 63 needs alot of money to get it to sound perfect. But i have only had a few hours listening and it could be down to some thing else like dirty mains signal so to be fair it needs longer listening
#13032 |
Odd! I thought it sounded really good. Give it some good hours then see if you think it needs more. No way was a CD67 better, it simply can't be!
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#13033 |
YES will do simon like i said i cant be sure it needs more listening to be fair but you did a grat job and im really gratefull coudn't have done it with out you mate
#13034 |
I've read various notes here about opamps oscillating. I don't think I've ever seen anything describing the symptoms of this, how to recognise opamp oscillation from some other problem. I don't suppose it's a motor boat sound that can suddenly come on after 3-4 hours playing (my current problem with an old 373 )Regards Pete |
#13035 | |
moved the PS caps closer to ICs at the small bypass one place, use the left space from lytic caps to fit ground pin and output pin of the 7805, bend the input in air and wire it to my voltage input. You'll have to remove the original link to 5V from the player. Check this Simon's how to for where to check: http://www.diyaudio.com/forums/showt...482#post912482 About judging the CDP sound all have been said. I've caught myself only using my last new records on... CDR, then shifted to good old CDs I know well. Damn, the player is more upgraded that I tought! Faster, holding the bottom far better. I also do not have the hyper speakers or top class amp... that tempers my listenings a lot.
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! Last edited by Malefoda; 4th September 2009 at 09:48 AM. |
#13036 |
Thanks Malefoda
I think i may be able to follow that, i have some questions though..... This is what i have to hand for main smoother i have 2x1000 35v elnas removed from 67 or 2x1000 25v rjh elnas for a cap before and after i have 220 16v silmics or 100 25v cerafines My guess would be 1xrjh main then silmics Could i use both rjhs to increase value? if so would i run them in series or parallel? Just to make sure series would be +/-+/- parallel +/+ -/- Did i mention an idiots guide? Cheers Ian Last edited by padman; 4th September 2009 at 11:01 AM. Reason: wrong name used |
#13037 |
If by removed caps you mean 15 year old ones put them in trash but to repair your rice cooker if needed.
I had no caps after as it will be just at the cap it will feed, or fit them in a remote place and use caps. For before I don't know, mine were fine without but I find the 1µF MKS I have with the 317 does a nice job.
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music! |
#13038 |
Ok if i go with just the main smoother, (rjh as they are new) should i use 2 as they are only 1000uf?
#13039 |
#13040 |
You misunderstand me (again, I may not handle english that well); I meant the player has improved more than what I tought buy judging it with new records and on CDR. The changes were more obvious with pressed CDs I know for years, e.g. The Almighty "Powertrippin" has the clearer bass I've heard on my CDPs, which means it's better than if it was worst or at the same level.
I guess pressed CDs help the sound a bit, I find, without having burnt CDs I own to compare, that the player gets more from a real CD. Should try with SHM-CD and Gold like MFSL ones. And as the regulated drivers should add to that my player will be a very good deal... at least I have to convince me
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Puffin |
| Page generated in 0.23558 seconds (61.27% PHP - 38.73% MySQL) with 11 queries |
