| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#121 |
He said it was spining but the laser was jumping about.
Its probably either a badly smoothed voltage rail or a RF lock problem. Its got to be something really minor thats causing the problem. Or a solder splash |
#122 | |
One Seriously Addicted to Audio and Electronics
Your CD53 uses yhe same PCB as the CD63, so if you mod it, you should be able to get it to the same audiophile altitude as a 63 On the other hand, an external DAC could be very nice too. What D/A chip do you have in mind? The DAC in the 53/63 is not bad, I've read somewhere that it's actually a copy of the famous CS4303! (not bad at all...). Ray. |
#123 | |
The horror of every electronic (hollow laughing in the background....) Did ya try service mode yet??? Ray. |
#124 | ||||
I spent hours looking for dry joints last night, to no avail. Perhaps I am not being methodical enough. Quote:
![]() Quote:
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#125 | |
#126 | |
#127 |
First thing is to check voltages leaving your regs.
#128 | |
One thing I did notice while following the 12v tracks around and checking for continuity, was that while -12v reaches the op-amps and I can see where it would reach the muting circuits (via tiny traces - now cutoff halfway) I cannot see how it gets to the -12v parts of those chips (tdxx..). There is continuity between -12v of these chips (ie. with one chips -12v pins and the next), but not with the -12v regulator. Could this be the problem? The service manual doesn't seem to show where the power traces go.
#129 |
The third pin of Q801 and Q802 are the +/- 12V outputs.
The third pin of Q811 is the 5V output When measuring make sure your common on the DMM is to gnd, Hdam can is a good place for this (ooops you removed it lol). Measure pins 13,20,28 on ic Q104 for 5v. Measure pins 1,2,8,9 on ic Q105/Q106 and QM01 for +/- 10V
#130 |
HI Simon,
I remember reading somewhere that the clock must start up no later than the rest of the player (if that makes sense). Is this still the case with your current clock power arrangements? Dodgy clock lock will affect transport. ( I think )
I w isH i cuold typpe bettr |
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| 6h5c |
| Page generated in 0.20871 seconds (59.77% PHP - 40.23% MySQL) with 11 queries |
