Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 26th August 2009, 08:08 AM   #12971
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
There is -5V in the player?
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 26th August 2009, 08:14 AM   #12972
Chivvyp is offline Chivvyp  United Kingdom
No, this is for an old philips player.
Pete
Old 26th August 2009, 08:47 AM   #12973
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Have you tried using a different 337?
I had a batch of poor quality or fake 337's and they kept giving up on me.
Lee.
Old 26th August 2009, 09:02 AM   #12974
Lee.
Hi Lee,
Yes, tried a couple and both the same. The odd thing is that it's working fine without the cap. Only get the voltage drop when I add it in. Take it out and the voltage is -5 again. It's driving me mad
Pete
Old 26th August 2009, 12:39 PM   #12975
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by Chivvyp View Post
Hi Lee,
Hi Pete
I had similar issues while building -12v sregs.... try to load the output with some resistance and see if it works.
Ricardo
Old 26th August 2009, 02:29 PM   #12976
Hi Ricardo,
Thanks for the advice, I'll try that. I'd assumed the DMM would provide enough of a load but I'll add a resistor in the output and see if that helps.
Pete
Old 26th August 2009, 03:55 PM   #12977
Malefoda's Avatar
I feel the need of checking again in mine..
About the player, my ears get used to the DOS or the DOS get wider, in space and in frequency. Is it buring in? That means it will get even better in few weeks
Old 26th August 2009, 04:40 PM   #12978
dublin78 is offline dublin78  United Kingdom
Hi
Please can someone help me with fitting a Tentlabs XO3.2 into my CD63?
http://www.tentlabs.com/Products/cdu...xo3/index.html
Instructions: http://www.tentlabs.com/Products/cdu...23mounting.pdf
I can work out where to take "clock out" from (bottom pin of crystal and right pin of CD02 cap).
The XO 3.2 contains an additional reclocking circuit for the digital output (SPDIF), which requires interrupting the signal between the decoder and the buffer and feeding it into "SPDIF in" on the XO3.2 board.
There seems to be no decoder on my CD63 board, just an empty slot for a SAA7345.
Where should I take my signal from?
Thanks guys.
Regards.
Michael
Old 26th August 2009, 07:00 PM   #12979
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Again, the real guard angel being Ray, check his website, all is explained.
Oh, thank you
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 26th August 2009, 07:06 PM   #12980
6h5c's Avatar
Hi Lee,
Pete
Pete,
I could be the negative version needs more or less capacity at the output. Sometimes they oscillate. Also the minimum load is 10mA, if you use 120R for the resistor from the OUT to ADJ pin, you already have that covered. Watch the polarity of the caps, plus is to GND with the negative version and the pinning is also different. Maybe superfluous info, but you never know...
Ray
Marantz CD63 & CD67 mods listHide this!Advertise here!
