| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#12951 |
Has any body got any ideas whats causing error codes 2 and 10 on my 63
#12952 |
One Seriously Addicted to Audio and Electronics
I first thought it could be a broken driver-IC, but now I see the spindle and focus are handled by two different drivers...
I'd advise to start checking the +/-10V driver supply voltages first. Are the fuses still o.k.? Then check if all the IC's are getting 5V, maybe there's a bad connection at your new regs somewhere. Regards, Ray Last edited by 6h5c; 24th August 2009 at 07:54 AM. |
#12953 |
Hi Bull I had the same codes on my 63 it was caused by a broken track at the dac check all solder joints and tracks around that area, mine was cap cd 15/or 16 if i remember correctly
Ian |
#12954 |
Thanks alot for help i will have a look . I cant understand why its stoped working it worked fine for a couple of days then just decided it did not want work any more
#12955 |
Are you the guy from Sheffield?
Not too far from the other guy in Sheffield? As has been said, you need to check the 5v supplies and =/-10v supplies. Lee |
#12956 |
Yes mate im in sheffield simont did the mods for me but he is away till saturday
#12957 |
Bull, did you get any further with your cd63?
I also, just thought I'd post an update pic of my cd63 as it is at the moment. ![]() Driver IC's are all regged with SPower's, dac, decoder, servo and rf all have diy regs for analog and digital supplies. I just have one more reg for the dac to fit and then I can start adding the tx's and psu's. It's really sounding incredible considering driver ic's and all 5v is running off one 30va tx (buzzes like a fridge mind you Cheers, Lee. |
#12958 |
#12959 |
Here is another member of LM4562 club
C:\Dokumente und Einstellungen\H.Wie...50809\IMGP0306 |
#12960 |
Hi THOMO looking very well hows it sounding, My 63 had HDAM bypassed tin hat opamps power rail and opamp caps replaced and it still sounded crap. Then SIMONT fited me 5 voltage regs on dac and servo and that really made it sound good but it only lasted a few days then paked up wont read discs. I am going to check some voltages in a bit i will report back with my findings
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Ben Hanke |
| Page generated in 0.21690 seconds (62.36% PHP - 37.64% MySQL) with 11 queries |
