Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st August 2009, 09:45 PM   #12941
Malefoda's Avatar
Send a message via MSN to Malefoda
Originally Posted by 6h5c View Post
Those ty-raps are DOS-unworthy however
How you dare Ray!
Of course it's in this shape for test purpose, the final set-up will be clean and fixed
After some more music there is definitively a big improvement from 3x 7805 to 7x LM317, don't know where but this is huge. Maybe the clock deserved the clean V ref?
Bull, maybe it's not related to the 5V regs, I experienced twice (once on my first CD-53 and once on a friend's one) the issue about faulty contact for closed drawer switch; it's moving or just broke then the drwaer want to close for ever and the gear jump a theet in a tic-tic-tic noise. Check continuity at connector JM02 between TRSW (TraySwitch) and Ground. If none at closed-state here is the prob. Or close the tray by hand and short TRWS and the next pin.
If it's not that maybe you can enter the diag mode and have a look to error codes.
Good luck!
Matthieu
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 21st August 2009, 09:52 PM   #12942
Thanks malefoda i will try that how do you get it to go in the diag mode
Old 22nd August 2009, 10:45 PM   #12943
Malefoda's Avatar
Check in the manual kindly shared by Ray aka 6h5c (check is signature) on previous page.
Old 23rd August 2009, 08:59 AM   #12944
jhmee9 is offline jhmee9  Bosnia and Herzegovina
I just joined "LM4562NA" club......
Marantz CD67SE, Onix BWD 1, Onix OA24,
Onix SOAP2, Onix OA601, Tannoy Eyris DC3, Kimber PBJ, Kimber 4TC
Old 23rd August 2009, 12:36 PM   #12945
What are the differences between a CD63 and a CD63 SE. I have both and they sound the same to me and look like they have the same components.
Old 23rd August 2009, 01:02 PM   #12946
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Look here.
The difference is not big, basically the SE has fancy/bigger caps here and there, and maybe better caps in the analog filter.
Matthieu: this PDF describes the U193/390R resistor section by the way. See page two in the modified section. Never noticed that!
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 23rd August 2009, 01:34 PM   #12947
Hi all i have just run diag mode and its showing error 2 which is a focus error and error 10 which says spindle error any ideas were to look next i have tried swaping another draw mec complete with laser and board but still same fault
Old 23rd August 2009, 04:56 PM   #12948
Malefoda's Avatar
Great Ray! Thanks once more!
Old 23rd August 2009, 06:19 PM   #12949
6h5c's Avatar
Old 23rd August 2009, 07:11 PM   #12950
Malefoda's Avatar
Bull, voltages are OK at U162 and U161 (from each to ground)?
Today I've had some nice listenings, and even once my stuff talked!
Hier spricht die Stimme der Energie
Ich bin ein riesiger elektrischer Generator
Ich liefere Ihnen Licht und Kraft
Und ermoegliche es Ihnen Sprache, Musik und Bild
Durch den Äether auszusenden und zu empfangen
Ich bin Ihr Diener und Ihr Herr zugleich
Deshalb huetet mich gut
Mich, den Genius der Energie
Page generated in 0.24635 seconds (61.63% PHP - 38.37% MySQL) with 11 queries
