Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 13th July 2009, 10:26 PM   #12651
RCruz is online now RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Matthieu
Do one thing at the time.
I fixed my star gnd near the mains input (actually bolted a smal pcb full of wires in the right most screw of the main pcb).
You can use instead the point near the output jacks.
PS: I would not remove any of the circuit board gnd connections before beeing very sure about that move !!!
Ricardo
RC
Old 14th July 2009, 12:38 AM   #12652
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Yep,
I'll see what I can do... even if I feel the interconnect, speakers and integrated will be a bottle neck soon or even already!
Anyone heard of this very hype version of the CD-53?
http://www.audiocar.pl/system-cas/tu...ker/jocker.htm
Fancy case... still a CD-53, wonder how much they stole from customer for this High-End player...
I've read some about DACs and some early post here (when Brent was wondering if bypassinf the HDAM was good... so long ago...) and around on the Net to put things under the light of real world... even if Internet is closer to no-life than burning fingers on our iron...
When I read (TNT) that they compare a CD67KI to a CD6000 and seems they are close (dull for our beloved CDP line in factory setup) so than means even if through the CD43--63KI the gap were small and marketed so the new players are still not that better according to price range?
On the technical side if I understand well what's nice in our NPC DAC is the fact there is no analog cheap filter stuff included to kil the music?
The conclusion is that even with our mods (say standard like DAC & Servo reclock, dedicated regs, DOS for the added parts and full of lovely new caps or such around) so even with our mods we keep far away in upper sphere or what? That's nice, seems even tomorrow with a new'n hot CDP on the market ours can make far better music for far less money... we can buy records!
Oh that's true, they are so badly mastered... check out the DCC or any Master Tape version, amazing!
Matthieu sleepless.
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 14th July 2009, 09:49 AM   #12653
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
The CD6000 use two of the SM5872 DACs, and an extra IC to split the digital signals. This probably adds extra jitter > sounds worse. Two DACs are more difficult to DOS. The rest of the player is not much different compared to the CD67, but the OSE uses HDAMs instead of opamps, which is nice. They probably put a second DAC in for marketing purposes .
That's right, you should steer clear of any DAC that has voltage out AND doesn't need an analog filter .
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 14th July 2009, 10:06 AM   #12654
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
I just modded a cd6000 KI for a customer, which is basically an OSE with the KI Toroid and copper plating with more Silmics.
I have to say, I've never had such an improved/impressive player after only a few mods. It really does sound fantastic and all I did is add a clock, SPower reg and swapped some caps.
I reckon the cd6000 is the best bang for buck player I've done so far.
Although I've just started an SA7001KI with promising results, lol.
Cheers, Lee.
Old 14th July 2009, 10:11 AM   #12655
6h5c's Avatar
Hm, maybe I should try one some day.
Although, the 6000 is no match for the 7001, especially if you DOS it . Not much sense in taking a step back.
Ray
Old 14th July 2009, 10:19 AM   #12656
Thomo's Avatar
I admit I found the 7001KI very bland at first. It had detail, but was flat and not very dynamic I thought.
It's come alive now after changing the dac filter elco's to ZA and also swapping the Cerafine's on the LPF/HDAM for ZA's (other cap changes made slight differences but these were the most impressive by far).
Did you find the dos such a large step up Ray? Considering the entire output section of the 7001 is already fully discrete, I wouldn't have thought it'd be such a huge difference. Then again, the existing output stage is rather complex.
Also, it's now only just on a par with my standard SA7003
Cheers, Lee.
Old 14th July 2009, 02:22 PM   #12657
6h5c's Avatar
Hi Lee,
My SA8400 was not very special either in standard form. CD playback was less than my tweaked CD67-OSE and SACD was only mildly better. But the DOS will make a big difference compared to the original circuit. I modded the original circuit first, with BG's and polystyrene caps and that was already a nice improvement. But the DOS added more detail, wider soundstage and more silent background. It's probably the large amount of negative feedback and complexity of the original circuit that is holding the player back. It is not supposed to sound too nice next to a SA15... (same DAC).
Finally the potential of SACD is revealed. Make sure you use the version for the SA8400 though.
A decent clock will also do wonders .
Ray
Old 14th July 2009, 03:01 PM   #12658
Malefoda's Avatar
Ray, that's maybe the reason why the Onkyo DX-711 (aka DX-7011 with remote on other markets) wich use a Toshiba TC9237 do sound very good (better than a CD-53 in standard form).
Lee, may I ask what is the real price, CDP as on used market and parts?
Old 14th July 2009, 03:49 PM   #12659
Thomo's Avatar
Another case of less is more then
I'm pretty sure that I'm going to sell it on to be honest, as I got a great deal on a brand new SA7003. With both in stock form, this was miles ahead of the 7001KI, although the build quality is no where near as good. It has a custom filter and a newer dac and I suspect may be a better base for modding.
I recently saw a cd6000 OSE on ebay for 80 "buy it now", but they sometimes go for less. Adding a clock, SPower reg and a load of caps is probably around the 200 mark. Seeing as the output stage is already done for you pretty well, therefor you have much less work to do. So for less than 300 all in, I reckon it's cracking value.
Regards, Lee.
Old 14th July 2009, 05:42 PM   #12660
6h5c's Avatar
Funny, the TC9237 looks like a SM5872 clone . The latter one has slightly better specs though. Onkyo uses a lot of nice DACs by the way!
Problem with integrated opamps and/or filter components is that you don't get to choose the opamp, and they are very close to the noisy digital die. The integrated resistors often have a huge tolerance.
Ray
Marantz CD63 & CD67 mods listHide this!Advertise here!
