Marantz CD63 & CD67 mods list - Page 1252 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th June 2009, 01:31 PM   #12511
Fidelity Audio's Avatar
Or a blow torch
Brent
Old 21st June 2009, 05:05 PM   #12512
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Brent
How does it sound with SACD discs?
Ricardo
RC
Old 22nd June 2009, 07:29 AM   #12513
That's what I tested it with LOL.
Very similar to mine that of course ony uses the poor layer
Brent
Old 22nd June 2009, 07:47 AM   #12514
ccschua is offline ccschua  Malaysia
Can I know if normally 16MHz crystal in a typical is used for what purpose ? Is it for remote control ? Or I mis read the label from 16.9 MHz.
Old 22nd June 2009, 08:14 AM   #12515
The 16.9Mhz xtal is for the dac and decoder
Brent
Old 22nd June 2009, 09:29 AM   #12516
Oh. it is a 12.000 NSK crystal with 2 tantalum cap beside it. I guess this crystal is for remote control. There must be another crystal mounted below transport mechanism, right.
Old 22nd June 2009, 09:40 AM   #12517
There is a blue xtal 8.46Mhz for the servo section.
Brent
Old 26th June 2009, 01:36 PM   #12518
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Well well well, look what I found:
http://www.audioupgrades.co.uk/sa7s1.shtml
Good work Brent, how does it compare to your CD63 now?
Simon
Old 26th June 2009, 02:39 PM   #12519
Been spying have you
It's very good, the details are up there with mine now. Also the bass has become what I consider spot on. I'll take it home over the weekend and test further.
If anyone can afford a second hand one of these and mod it they will have a very nice cd player indeed.
Brent
Old 26th June 2009, 07:55 PM   #12520
Malefoda's Avatar
Send a message via MSN to Malefoda
Well guys,
far away from such out of reach luxury machine here I am with my CD-53
I'm cutting test boards for my DOS right now, not the final resistors (will order stuff for a fiend so some Takman or Holco for me), not the final caps (left Rubycon ZL from op amps) but almost the definitive tight fit.
I have to make up my pind about how to move or not the LM317/337 Raygs closer and remove a pair of cap, making a second pair of Raygs, making TeddyRegs, buy better caps...
any problem fitting these boards as a layer over the main PCB as done with clocks or my Flea in my player? It's a room problem, so if they can go // over the DAC head that's fine.
the chokes L1 L2 they have a dot on top wich shows a way, wich one is it?
Need rooooomm
Matthieu
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Copyright 1999-2017 diyAudio
