Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th October 2008, 09:52 AM   #11101
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
I've only ever used two regs on the decoder of a cd63. I think I used three on the cd67, but that is a different thing altogether as that chip incorporates Servo also.
I have discontinued my CD63, as like Simons, the thing kept going wrong due to having to remove the board with all the extra parts to work on it. (Although I managed to repair it without "professional help", lmao.
I got a great bargain on an old battleship Marantz CD94! This is fairly well modded now, some low-noise regs, full cap replacement, output stage completely re-worked - opamp I/V and discrete output, but has only one extra psu installed so far. I am dumbstruck by how much better it is compared to my cd63.
Cheers, Lee.
ps - I'll get back to those guys about boards very soon
Old 26th October 2008, 12:59 PM   #11102
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Hi Lee
Maybe this one is my last mod in the CD53.... I will feed the decoder on it´s psu because I can access it from below without lifting the board out (I left the big hole below the chassis open).
I also have a mains line near the decoder (used for the clock psu) and the TX is small enough to be placed near by.
This will be one of the safest modds I have done.
I had professional help... but all the hand labour was mine
I am taking it easy now.
Ricardo
RC
Old 27th October 2008, 07:31 PM   #11103
Fidelity Audio's Avatar
Cheers, Lee.
But you got "professional help" on the CD94 LOL
Brent
Old 27th October 2008, 07:32 PM   #11104
Originally posted by Luke
Ken Ishiwita would be so proud
Nah it's well above his head LOL
Brent
Old 27th October 2008, 07:34 PM   #11105
Originally posted by RCruz
Hi Lee
Ricardo
Ricardo you seem to do things well so I would'nt worry about over doing it. Some people just manage to blow up stuff by looking at a circuit board hehe
Brent
Old 27th October 2008, 07:44 PM   #11106
Thomo's Avatar
Brent
LOL.
Lee
Old 28th October 2008, 07:49 AM   #11107
Hi Ray, Brent, Martin and others,
I hope this is not too off topic.
Although I have a Rotel RCD965BX, a lot of the information and discussion on this thread applies to that player too, especially the discussion about multiple regulators and transformers. Following this thread, I now have a total of 13 regulators (and 5 transformers) installed, all of them the superrayreg type with LM317/337. Although the Rotel has only a ground plane and plated through holes for the ground pins of caps and regulators (no grounfd taces at all), I have taken ALWs advice and connected the adjust pin (Kelvin sense point) directly to the ground pin of the relevant chips.
All the regulators are mounted within 4cms of the relevant supply pins and I took Martin's advice and caution about having large, low impedance, caps at the output of the regulators. I used 100uF 10V Rubycon ZL caps as the output/smoothing caps. The impedance of these is 0.3 Ohms and this seems to work just fine.
Rotel uses a single NE5534 op-amp per channel in the output stage and I have changed this to an LME49710, which is the single version of the popular LM4562.
Each change brought a significant if small improvement. The three major improvements were installing a Tent XO module with its own psu, changing to the LME49710 op-amps with separate transformer; and separate regs for each DAC supply, also with separate transformer winding for analog and digital. The SAA7323 DAC now has 6 regulators - 2 analog and 4 digital.
I have been watching the discussion about the Discrete Output Stage and have been wondering whether I could use part of it to replace the op-amp. I don't think I need the bessel filter part of the circuit so I'm thinking that I could leave that off the pcb and use everything from T1/T2. My idea is to tap the signal from the DAC just before it enters the op-amp, bypassing it completely, and use the DOS as if it were a discrete op-amp. I think the original op-amp in the Rotel has a gain of 1.8. Would I need to change anything on the DOS pcb.
Can I buy the DOS pcb anywhere?
Thanks for all the information and discussion and congratulations on such a useful thread.
Joe
Old 28th October 2008, 01:51 PM   #11108
RCruz's Avatar
Well, I use googles to stare at the PCB.... maybe that is why it does not blow on first sight.... LOL.
RC
Old 28th October 2008, 05:58 PM   #11109
RCruz's Avatar
Hi Brent
Following your pdf, I built a PSU for the decoder with separated windings for Digital and Analog.
After some reading (and your last e-mail), I understand that all psu lines in the decoder should be connected to the same external psu.
Does this mean I can not separate analog from digital using two separated psu´s ?
Ricardo
RC
Old 28th October 2008, 06:02 PM   #11110
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Ricardo,
You can separate them, it works fine.
The only thing I've found you really can't do is to have off-board power supplies for the add-on clocks!! Mine are now internal and as well as detail increasing (they are better power supplies and we did another mod) my noise problem pretty much dropped off.
Simon
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
thierry67
Page generated in 0.24309 seconds (67.70% PHP - 32.30% MySQL) with 11 queries
