| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#11001 |
that's a good point (and one of the reasons I hat eelcos too!).
Combining large caps can indeed lead to some very odd effects, too, often you can clearly see on a scope two overlapping rates in the settling 'tail' after a step change in voltage. No wonder it sounds odd. Yes big caps can give 'big' bass; they can also give you very, very wrong bass too, unless you are lucky or willing to work through a lot of permutations! |
#11002 | ||
Hi Martin,
Thanks for your reply. Quote:
On the other hand, would I need to use this "work around" if I used Black Gate or Rubycon ZL caps in this position. I understand that their ESR is not so low as the Os-Con. On the analog op amps I have put the rayrags very close to the chips and bypassed with 220uF Silmic II. This seems to work well - obviously the Silmic II are not very low ESR. Thanks again for your advice, Joe |
#11003 |
Magneto the Gravity Man
Over 11000 posts.........
What did you start, Ray ????? Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#11004 |
One Seriously Addicted to Audio and Electronics
I didn't even notice it was another thousand...
I guess it's becoming a normal thing... ![]() Ray |
#11005 | |
Hi Martin,
I also note Brent's comments about potential issues with two large caps at the output. In the schematic for the discrete output stage on Ray's website, the 7812/7912 regs are followed by a 100uF Black Gate. This looks like the same arrangement I have, but with LM317 based rayreg, so can I presume that 100uF BG or Rubycon ZL will be OK for my application? Just a note that Black Gates are hard to get in Australia and even more expensive when ordering from OS,now that the AU$ has taken a 30% nose dive. However, RS components up the road from me stock Rubycon ZL in several values.) Thanks, Joe |
#11006 |
i just buy a used unit marantz cd67se, is fully in stock condition without any modification... i heard from this someone can do same modify to improve the sound quality...i saw from this thread regarding disable the HDAM can improve the sound...so mine is in stock condition, can i just disable it without doing other modify to improve the sound? how to disable it?....pls help me
#11007 | |
Just go to the first post and follow Ray´s indications. IMO if you disable the HDAM, you should upgrade the output opamps with something better or the gains will not be as expected. (I used LM4562 with great success). Ricardo
RC |
#11008 | |
hi, what is the opamp location? is it Q605 & Q606? is it just take out the old opamp and put the new one? have to do other? how many pcs opamp i need? where the actual location on pcb of the opamp? sorry...i not newbie on this...pls help
#11009 | |
Excellente And I got my first mini milestone post Brent |
#11010 | |
Brent |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Puffin |
| Page generated in 0.25338 seconds (64.05% PHP - 35.95% MySQL) with 11 queries |
