Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th July 2008, 06:56 PM   #10501
6h5c is online now 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Originally posted by RCruz
I still have a small issue..... The remote only works if pointed at less than one inch from the sensor in the CDP.
I do not know what started this but it is like that for a couple of month now.
Try an electrolytic (10...47u/16V) in parallel with CY01 on the front panel PCB, worked for me. I noticed the IR receiver somehow becomes less sensitive when RY11 is replaced by an inductor.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 14th July 2008, 07:18 PM   #10502
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Ray
Ray lurks and emerges with the answers!
Old 14th July 2008, 07:23 PM   #10503
6h5c's Avatar
One has to keep track of things
Old 14th July 2008, 07:35 PM   #10504
Fidelity Audio's Avatar
Default Re: Ricardo the TX behind the mechanism?
Originally posted by magilla
Also a public thanks to Brent for cleaning up my C1.
No problem, it will be posted tomorrow
Drill the back panel and use a nut and bolt for the tx. Most txs come with insulation pads
Brent
Old 14th July 2008, 08:38 PM   #10505
RCruz is offline RCruz  Portugal
RCruz's Avatar
Thank you Ray
Even with new batteries, the remote only works at about 15cm from the CDP.
I will surely try this cap in CY01....I will solder it from the back of the pcb so I do not need to remove it. .....
Ricardo
RC
Old 14th July 2008, 09:09 PM   #10506
RCruz's Avatar
Originally posted by avr300
You must admit, it would be a pretty good reason and easy to fix.
RC
Old 14th July 2008, 09:16 PM   #10507
RCruz's Avatar
Can I use a 10uF 35v Ruby ZL ?
The other option is a 120uF Pana ... too big maybe.
Ricardo
RC
Old 15th July 2008, 07:32 AM   #10508
avr300 is offline avr300  Denmark
avr300's Avatar
Just use one of the original ones, you must have a bunch of them after having upgraded the whole machine.
Just grab what comes handy.
/avr300
Old 15th July 2008, 08:25 AM   #10509
Also check RY11 for resistance. I've seen these go high resistance before, usually after the ribbon not being inserted correctly and shorting 5v to gnd. RY11 should be 4.7 ohm.
If these things mentioned in the thread do not not cure the problem then you may have a duff connector (or you are holding the remote the wrong way round )
Brent
Old 15th July 2008, 11:31 AM   #10510
pzogal is offline pzogal  Europe
Default output stage again...
another thing about output stage, this time Ray's discreete.
how about substituting R11 with a pot ?
couldn't one adjust DC offset this way and get rid of the output cap ??
greetings,
Pawel
i am going to fit discreete output, I am just curious, the cost will be rather small for me, I just need some Rs and low-pass filter components
Page generated in 0.25701 seconds (48.87% PHP - 51.13% MySQL) with 11 queries
