Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 21st June 2008, 11:14 PM   #10211
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
I'd recommend a 15V tranny. Heat is bad for electronics.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 22nd June 2008, 08:40 AM   #10212
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Originally posted by RCruz
I specifically built the opamps dedicated psu with a 2x18v TX following otherīs ideas on this forum... I intend to use the same psu for the future discrete outputs...
Ricardo
I'm pretty sure Brent is running his discrete stage on +-15v. Less volt-drop compared to 12v.
I am running my discrete output on 12v, does upping the voltage improve the sound any?
Lee.
Old 22nd June 2008, 12:17 PM   #10213
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Only ever run mine on +-15v.
Old 22nd June 2008, 12:19 PM   #10214
SimontY's Avatar
Default Re: C1 Clock report
Gentlemen
As agrred, here my report after implementing the C1 clock on the dac:
Improved dynamics with noticeable silences.
Much better stereo image.
Stage depth and stability improvements.
Instrument placement better defined.
Instrument size "volume" recreating an holographic auditive picture.
Recording place echoes and reverbs well recreated (Laurie Anderson "Bright Red")
Much better instrument diferentiation and positioning in the soundstage.
Particular improvements in attack and decay.
Voice timbre and placement extraordinary improvements (Tori Amos)
Piano notes and reverb recreated with aplomb.
This mod completely transformed the player.
Now I believe that PDM signal must have a good clock to result.
Ricardo
Gosh, that's quite a list! Completely agree with all of that. The servo reclocking isn't quite as striking but does fix the hazy treble and provide more of the subtle details. Your player must be getting fairly "high end" now
Old 22nd June 2008, 12:19 PM   #10215
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Simon
Can I drive the LM4562NA opamps at +-15v?
RC
Old 22nd June 2008, 12:20 PM   #10216
SimontY's Avatar
Hi Simon
Hi Ricardo,
Yep, I run the 4562s in my preamp from +-15v S Powers, sounds great.
Simon
Old 22nd June 2008, 12:21 PM   #10217
nhinstruments
RCruz's Avatar
Default Re: Re: C1 Clock report
Yes... now it is starting to compete with my ariston
RC
Old 22nd June 2008, 12:22 PM   #10218
nhinstruments
RCruz's Avatar
Hi Ricardo,
Thank you Simon
Maybe that will be the temporary solution.... I will build some sregs for +-15v
RC
Old 22nd June 2008, 12:26 PM   #10219
SimontY's Avatar
Thank you Simon
That'll certainly help, but also check this out:
http://www.national.com/pf/LM/LM4562.html
You can use up to +/-17. You'll not be able to use 16v caps though.
Simon
Old 22nd June 2008, 12:29 PM   #10220
nhinstruments
RCruz's Avatar
I would like to only change the sregs... I am using 220BG16v on the opamps... is it enough for +-15v ?
RC
Marantz CD63 & CD67 mods listHide this!Advertise here!
