Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th June 2008, 08:25 AM   #10101
This CD63 project remains one of the most popular.
Old 9th June 2008, 03:27 PM   #10102
RCruz is offline RCruz  Portugal
RCruz's Avatar
Originally posted by rowemeister
The better the reg the better outcome you will get. A Raygulator type device will work a treat
Hi Brent
Can I use a LD1086 for the clock psu on the dac ?
I have only one of those and read they can be unstable with little loads... can it be an issue ?
By the way, I just installed the DAC digital +5v rayreg and it is burning beautifully.... better stereo image and stage depth.
Ricardo
RC
Old 9th June 2008, 09:21 PM   #10103
Fidelity Audio's Avatar
The 1086 should be fine, current required here is very small.
I would'nt bypass the the Oscon.
Brent
Old 10th June 2008, 08:47 PM   #10104
magilla is offline magilla  Belgium
Default To separate or not?
I notice that Brent's player mod list has the DAC and Decoder each powered by a PSU, with 5V feeds for analogue and digital bits; is it best to use power the digital and analogue together, or the chip( DAC or decoder) as Brent has?
The single channel static noise vulnerability seems to have been sured by 1086s on main 5V feed and on the output opamps 12V. All three were free samples, so its a pretty good tip.
Old 10th June 2008, 08:55 PM   #10105
RCruz's Avatar
Default Re: To separate or not?
My experiments indicate that each +5v should have it´s own dedicated psu.
My CD 53 now has 6 TX windings working independently.
Everytime I add one more TX, a big improvement is felt.
Brents machine sumarizes all of the known best practices in this forum.
Ricardo
RC
Old 10th June 2008, 09:17 PM   #10106
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Default Re: Re: To separate or not?
Ricardo, you are the teacher's pet!
I have also found that each regulator and psu added gives rewarding improvements.
Simon
Old 11th June 2008, 08:47 AM   #10107
I used a 2X 9V 15VA tx for DAC and a 2X 9V 7VA tx for decoder. All 4 supplies use a seperate winding of the two transformers with seperate diodes and caps.
I used the larger tx for the dac as it uses more current than the decoder which uses very little
Brent
Old 11th June 2008, 03:47 PM   #10108
RCruz's Avatar
Default Re: Re: Re: To separate or not?
I am not.
But I can recognize a good work.
Ricardo
RC
Old 11th June 2008, 03:52 PM   #10109
At least i've not had to repair yours Ricardo lol
Brent
Old 11th June 2008, 04:00 PM   #10110
SimontY's Avatar
Default Re: Re: Re: Re: To separate or not?
I am not.
Ricardo
Just joking my man!
Brent
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Ben Hanke
Page generated in 0.23815 seconds (66.49% PHP - 33.51% MySQL) with 11 queries
