Marantz CD63 & CD67 mods list - Page 1010 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th June 2008, 08:49 PM   #10091
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally posted by Malefoda
Got my 470/16 BG for the DAC analog. These things are big, do they fit around opamps?
Anyway I'll stick with the 220/16 BG there...
Originally posted by rowemeister
Quality caps are always big
The 470uF JUST fit with a little squeeze, the 220uF fit perfect.
I have just the same issue.
I think I will remove the 220uF BG around the opamps and squezze the 470uF in.
I will use the 220uF on CD15 CD16.
Ricardo
RC
Old 5th June 2008, 10:44 PM   #10092
nhinstruments
RCruz's Avatar
Personally I think you should connect it to the star earth that way the gnd references are the same on all pcbs.
Hi Brent
Fitting the DAC clock on pin 28 (using U196) will be easy.
Can I remove the stock X´TAL psu line ?
Maybe I could remove RD01 CD04 CD05.
Ricardo
RC
Old 6th June 2008, 08:27 AM   #10093
Fidelity Audio's Avatar
You still need the 5V supply for the clock cct on the dac. Your best bet is to remove RD01 and solder in a 7805 so that it's more isolated from the rest of the circuit. Supply the 7805 from underneath the PSU from the big smoothing cap (+20V). Just check to see if the reg gets warm, I don't think it will.
Doing this will require the psu gnd connecting to star gnd
Brent
Old 6th June 2008, 09:44 AM   #10094
nhinstruments
RCruz's Avatar
Hi Brent
You mean I can link the 7805 to the new PSU2 ?
RC
Old 6th June 2008, 10:13 AM   #10095
Yes, supply voltage from the main smoothing cap before the SPower regulation.
Brent
Old 6th June 2008, 02:10 PM   #10096
nhinstruments
RCruz's Avatar
Brent
Should I use a LM340AT instead of a 7805 to improve noise rejection ?
Or maybe a LM317 with a gyrator ?
Ricardo
RC
Old 6th June 2008, 02:14 PM   #10097
Yes of course
The better the reg the better outcome you will get. A Raygulator type device will work a treat
Brent
Old 6th June 2008, 03:34 PM   #10098
nhinstruments
RCruz's Avatar
Yes of course
Brent
While I wait I was thinking about placing one Raygulator on +5v DAC Digital.
I already have a dedicated PSU for this reg.
What improvements should I expect from such modd? (I already have the Spower on DAC Analog and the sound is very good indeed with good integration and much better detail.)
Ricardo
RC
Old 6th June 2008, 03:54 PM   #10099
Using something like an SPower will bring bigger gains but again thats going to cost alot more money!! So a Raygulator here will bring about better timing, a more precise sound etc. There will be less of that digital sound. Do it.
Just using 7805 everywhere brings gains so a Raygulator will improve further.
Brent
Old 6th June 2008, 06:43 PM   #10100
nhinstruments
RCruz's Avatar
Ok
I will replace RD04 by the raygulator, remove CD07 and replace CD06 by a 470uF Oscon.
Do I need to bypass the OsCon ?
Ricardo
RC
Copyright ©1999-2017 diyAudio
