| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1001 |
i was going to do some test to see the drive capabilities of the dac
just a bit of info for passive filter so far removed output caps, muting, headphone, DAMH( very much improved for such cheap mods oh yes forgot to fit opamps in sockets, still got resonable signal out. yes restricted on frequency looks promising for the passive filter to buffer allan
Indecision makes the world gone round. Maybe |
#1002 | |
LowFI allan
#1003 |
ash_dac
you got post 1000
#1004 | |
haha You removed the hdam ? What was the voltage of the signal you got ? |
#1005 | |
hdam yes (bypassed all) suggestion by a fair few on here and elsewhere that with a better opamp, the hdam doesn't help. i tend to agree with them on schematic voltage into opamp 1.4v without opamp, it goes though the feedback caps/resistor circuit as i said restricted frequency. will have to measure it. thinking about making small pcb to plug in opamp sockets at lest that way i don't have to keep removing pcb to test ideas. allan
#1006 | |
One Seriously Addicted to Audio and Electronics
I put my scope on the DAC and measured between 0.5 and 1uS for a period, so my guess is the output frequency is pretty high, 32*Fs or 1.411MHz. The first stage does some passive filtering and the first opamp summs and amplifies both outputs to a single ended signal. At this point it's already more or less analog, with lots of HF residue. Then a second opamp stage filters a bit more. If you take out the opamps, like Allan did, you have reasonable music, with lots of noise. The HDAM circuit only acts as a buffer, so if you bypass it the amplitude of the output signal stays the same. Regards, Ray. |
#1007 |
just changed C605/606 from 1000pF to 470pF
and R611/612/605/606 from 10k to 12k1 listeninig to Nora Jones before and after much much better balanced sound highs to lows recommended Ray's filter suggestions allan ps all other caps in filter standard
#1008 | |
but gave me better view of dac output hmmmm voltage used to current out where you need IV converter not really reasonable music maybe not as good as MP3 Hmmm converts to single ended I have balanced input capability on my preamp. why this cdpayer is good for experiments allan
#1009 | |
I've never opened up my Marantz...... |
#1010 | |
Magneto the Gravity Man
There's no reason you could not retain the balanced output from the DAC. Possibly build a daughter board to plug into the opamp socket?? Andy |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| Page generated in 0.20299 seconds (57.43% PHP - 42.57% MySQL) with 11 queries |
