Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 23rd May 2008, 08:40 PM   #10031
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Will report the results....
Ricardo
RC
Old 24th May 2008, 06:14 AM   #10032
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Default Re: Re: Re: Quite a long thread
Originally posted by rowemeister
Haha a great way to introduce him to electronics.
Brent
Originally posted by RCruz
Hi Ray
I had a similar experience the first time I built my Steimusic Philips CDP.
The cap was on reversed polarity
Now it plays wonderfully.
Ricardo
Yes, it was a learning experience . The cap was on the -10V and he connected it with minus to GND...
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 24th May 2008, 03:04 PM   #10033
nhinstruments
RCruz's Avatar
Default Re: Re: Re: Re: Quite a long thread
Reversed polarity is quite a common mistake.
As my work involves using a PC 12 hours a day, my eyes are not perfect anymore so....
My CD worked for two hours and I always heard a little frying noise that I could not identify... then crack and the cap it started to leak.....
Some cleaning a a new cap solved the problem..
RC
Old 24th May 2008, 03:07 PM   #10034
nhinstruments
RCruz's Avatar
If you are putting the tx over the opamps I would (just in case) put a shield between and of course connect this to gnd.
Faraday´s cage to avoid induced electromagnetism right ?
RC
Old 26th May 2008, 09:38 PM   #10035
nhinstruments
RCruz's Avatar
I am thinking I must place the 2x9v TX outside. (Leaving it inside would take the place needed for the future discreet output stage)
I can fasten it to the back plate (outside near the stock TX) and pull the wires in through a hole...
Should I expect any problems from that setup ?
Ricardo
RC
Old 26th May 2008, 09:56 PM   #10036
nhinstruments
RCruz's Avatar
Another question....
The discreet output can be fed by my 2x18V Nuvotem ?
Did I miss something when programing the mods ?
I am using this TX for the opamps... can I use it in the future for the discreet outputs?
Feeling a bit
Ricardo
RC
Old 27th May 2008, 07:59 AM   #10037
Fidelity Audio is offline Fidelity Audio  England
Fidelity Audio's Avatar
Hi Ricardo
The tx mounted externally is fine and yes the opamp feed is fine for the discrete supply.
Brent
Old 27th May 2008, 04:55 PM   #10038
nhinstruments
RCruz's Avatar
Hi Ricardo
Thank you Brent
I was starting to doubt myself
Soon the dac psu will be ready... after that will be the clock
RC
Old 27th May 2008, 08:35 PM   #10039
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
No clock yet?? Bad boy!
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 27th May 2008, 09:22 PM   #10040
nhinstruments
RCruz's Avatar
I did cut the earth loop "acoustica.org.uk" and things god a lot better.
Afet all my experiments, I believe this machine needs two clocks:
One for the DAC to optimyse timing, spatial presentation and overall sound cohesion.
And one for the servo where we get detail, dynamics and insight.
I am saving €€€€ right now
By the way, I love your integrated... I am wondering if the power amp G&W Class A is as good or better.... Do you know this big brother ?
Ricardo
RC
Marantz CD63 & CD67 mods listHide this!Advertise here!
