| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#991 |
Good idea. I've started a new thread. |
#992 | |
Magneto the Gravity Man
Why not purchase a bitstream dac cd-player instead? Kenwood DP 7040/7050/7060 are all DAC7 bitstream players and are cheap to buy. Why not start a new thread on this topic?? Andy |
#993 | |||
No sorry - I don't but see Ray's post below. Quote:
Well, maybe some say it SHOULDN'T make a difference but all the reports I have read from people who have tried it have been very positive!!!! OP amp outputs are seldom in class A even if they are used at low levels and RELY on high open loop gain and feedback to LOWER not MINIMISE crossover distortion. Applying a fixed drain (source?) current to force the NPN output transistors into Class A does not minimise crossover distortion but eliminates it completely!! Quote:
Andy |
#994 |
Guys ,10 years I work with PC hardware.I know that all CD-Roms and CD Players have firmware.Why the peoples in the DIY CD-Player thread can think for a new firmware for the DIY Player with MP3 ? Why any people in this thread can`t work for any firmware with MP3 support for the Marantz CD6x series?
How I can mod my CD65,because I know that my player isn`t the perfect player?If any can help for the CD65 will be great |
#995 | |||||
One Seriously Addicted to Audio and Electronics
100n/0,1uF ceramics or MKT will do fine (Black Gates??). These caps are indeed coupled to the input side of the rectifier bridge that is made up of two or four diodes. Quote:
You can connect the clock's output signal to the player by removing CD02, CD03, XD01, RD02 and U209. Connect the output of the clock to the hole of U209 that's next to CD05. If you drop me an e-mail I can send you the CD67 schematics if you like. That might enlighten things a bit. Quote:
Regards, Ray. |
#996 | |
Andy |
#997 | |
Hi. You really need to look on threads relating to the TDA1541 and TDA1541A. There are many mods posted for this DAC. Otherwise, start a new thread dealing with firmware updates. Andy |
#998 | |
Audio-CD players also have software, that's correct, but the problem is: they don't have flash ROM's! So it's not possible to upgrade the uC software, unless you are able to write, compile and program a MN187164 controller Besides, most guys here are in the audiophile section, so we don't like MP3's Regards, Ray. |
#999 | |
the future of HIFI ? |
#1000 |
Does anyone know anything about pwm signals, and pdm signals ? A pwm signal comes out the Marantz dac.... Is this pwm signal at 44.1khz or is it higher ? Does the 1st stage after the dac just generate a voltage from the difference in the +/- left/right output ? (still 0/1 pulse) ..and the low pass filter turns the pulse into audio ? |
| Page generated in 0.22682 seconds (61.41% PHP - 38.59% MySQL) with 11 queries |
