Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th March 2005, 02:37 PM   #1
Algar_emi's Avatar
Default My new 1545-cs8414 nos DAC
Hi. Here one of my current project. A small none-oversampling DAC using the 1545 DAC and CS8414 receiver. It is running on battery and has class-A op-amp outputs, local regulators and BG caps.
It has Scientific Conversion high bandwidth dual primaries transformer. This transfo offer the 110 ohms AES/EBU and 75 ohms SPDIF dual inputs.
I did 2 versions of PCB. The second version has balanced outputs in addition to single-ended. It is using the BB DRV134 IC's for balanced conversion. The second version is also using 4 batteries for full dual mono power supply.
Here the version 1 PCB. It is using AN8005 SMD regulators.
Old 19th March 2005, 02:40 PM   #2
Algar_emi's Avatar
It is a collection of differents ideas, some from the dAck! DAC, some from the Scientific Conversion white papers and some articles on the net. PCB desing are from me.
Here a summary of the features and specs.
Old 19th March 2005, 02:43 PM   #3
Algar_emi's Avatar
I'm building the enclosure for the version 1. Here the back panel.
It has the battery charger input connector, the AES/EBU Neutrik and true 75 ohms Amphenol insulated BNC digital inputs and Cardas RCA audio outputs connectors.
They are mounted on 1/8" alu plate.
Old 20th March 2005, 03:49 AM   #4
Algar_emi's Avatar
The front panel that I just completed. It is a double plates construction (I'm using a recycled very nice and strong alu enclosure). Using this assembly, I was able to hide most of the drill holes and mounting hardware, only showing 4 nice little stainless steel hex screws.
The Front plate is from a nice aluminium Hayes modem casing. It is already anodized and well finished and the grooves give some look. I used the same trick for the faceplate of my Aleph30.
We can see the power switch (On-Off-Charge) and the two leds, Power On (Blue) and Sync (Green). The leds are recessed and shown throught small pin holes. We see only a small slot for the switch.
Not too bad I think
Old 20th March 2005, 03:53 AM   #5
Algar_emi's Avatar
Here a side view showing the double plate, the switch mounting bracket and the leds wiring
Old 20th March 2005, 04:23 AM   #6
Very nice!
Old 20th March 2005, 09:09 AM   #7
Banned
Send a message via Yahoo to Elso Kwak
Exclamation Cannot open the file
Hi, I cannot open the file as it seems not to be a valid Winzip file.
Old 20th March 2005, 09:25 AM   #8
diyAudio Moderator Emeritus
jean-paul's Avatar
It is a plain text file. I have no trouble opening it.
It's only audio
Old 20th March 2005, 09:42 AM   #9
Banned
Windoz huh......
This file has a zip extension so this stupid PC tries Winzip.......
Old 20th March 2005, 11:03 PM   #10
It had no file extension when I tried downloading, so I just gave it a .txt extension -- I assumed that's what he'd be sending
Newbie help on 1545 non OS DAC! Horizons Digital Source 1 1st December 2004 09:08 AM
Page generated in 0.09912 seconds (78.22% PHP - 21.78% MySQL) with 11 queries
