Dear Audio-GD,
Lots of hard work there and on your website…
Which Digital filter did you use?
To date, the best sounding DAC designed I’ve built used dual SAA7350. However to gain the best from the SAA7350 the internal OPAMP’s must be bypassed, and great care taken with the Vref to each switch capacitor. Also it must be operated in 384fs Mode.
Needless to say the Clock is critical.
Interestingly, I much prefer the sound of the SAA7350 operating with its internal Switch capacitors over using the external DAC 7 TDA1547… even though the DAC7 has vastly improved measurements???
Do you have a good source of SAA7350? I’m considering designing a CD player using dual SAA7350 and the PMD200 (If I could also find a good source of PMD200), looking for about 2K Pcs. of the SAA7350 & 1K Pcs of the PMD200…
John
John
In China
I cann't found some new IC, so in my DAC, it can use DIP-IC also SMD-IC,, the digital filter it can use most of 28 Pin IC, for example PMD100, SM5803, 5813,5843, DF1704,1700 and any more.
The SAA7350 I've use one PCS in each channels , it's a cheap IC, only need a few dollar .
JohnW said:Dear Audio-GD,
John
Hi JohnW
You made your dac which used the SAA7350 and you bypassed the internal opamps .
My question is did you use the DOL and DOR output , is this a bit stream which is not PCM and needs only a high order lowpass filter to get the audio .
Arthur
Arthur,
Good question,
On the Pink Triangle Dacapo I decoded the BitSteam data outputs to basically generate what is now commonly referred to as DSD (but operating at 192fs as apposed to DSD slower 64fs or 128fs).
This Bitstream is extremely - READ EXTREMILY sensitive to phase noise (jitter), and any form of edge error, and needs to be re-clocked to an ultra low Phase noise clock source before being feed to a LPF. The great advantage of this method is that the output is a low impedance voltage output, that requires no I/V conversion and is filtered (significantly removed of HF energy) before being fed anywhere near “Analogue” circuitry.
I quote “Analogue” because in fact the digital logic that is used to re-clock (Latch) and Buffer the outputs must be considered analogue in nature.
See the Crystal semiconductors data sheet / App. note on implementing the CS4303 for a very in depth discussion on designing a Bitstream (DSD) discrete DAC. However the CS4303 only operates at 64fs (I use its outputs as a semi-decent DSD signal source).
The SAA7350 outputs at 192fs and needs to be decoded to a DSD stream with simple logic (its output is more like PWM not DSD), however this “PWM” needs to be decoded into “DSD” before it takes on its correct none distorted form.
Implementing a discrete Bitstream / DSD DAC with low distortion and noise is NOT a DIY project – requires the greatest of layout and design skill – and SMD components.
When I mentioned I don’t use the internal OPAMP’s – I meant I used off-board I/V’s (as implemented in the Cambridge Audio IsoMagic) – the SAA7350 was never intended to be used in this manner, and using external I/V results in higher distortion, however it sound significantly better.
John
Good question,
John
CS4303 DATA SHEET
Hi John
Its hard to find a data sheet on the CS4303 do you have a copy of this data, being a discontinued part Crystal will not support it any more. Is there still a source of the CS4303 chip.
To convert the "PWM" output to "DSD" what in basic terms do you need to do to it. Can this be done with simple logic do you have you a circuit .
Are there any other chips to your knowledge that provide this signal or have they stopped doing it in current chips as everthing is coming out as a PCM signal. I get the impression that you need a DSP to convert a "PCM" signal to "DSD" is this right.
Arthur
JohnW said:Arthur,
John
Hi John
Arthur
JohnW said:... looking for about 2K Pcs. of the SAA7350 & 1K Pcs of the PMD200…
John
John, I don't think you can buy the PMD200 anywhere.
First you have to pay lots of $$$$ for an HDCD license...
I don't know if things have changed, though.
But take as an example the PCM1732 dac from TI/BB.
It's has integrated HDCD digital filter, some brands (like Linn) use it.
But you can't even find the datasheet on TI's web site.
Hi Carlos,
I have a HDCD license; in fact the Pink Triangle Dacapo was the first product in the world with HDCD... I worked closely with the guys at Pacific Microsonics to insure that our product met there high standards - as it would be the first product to be released to the public incorporating HDCD – and they could not afford bad press….
The BB device is relatively poor by my standards - which is a shame. I would have also liked to have used the HDCD filter in my digital amplifier...
John
John
Arthur,
I would like to stress that when I said “convert from PWM to Bitstream” I meant in the sense of the SAA7350 Bitstream outputs.
The 7350 Bitstream outputs where originally only intended as test points – so are not correctly formatted for pure PDM (DSD / Bitstream). Basically you need to logic “AND” the 7350 PDM data output (which resembles a PWM stream) with the Master clock (divided by 2 = 192fs) – this then converts the “PWM Type” data into a PDM / DSD Bitstream. At the same time, this needs to be re-latched with the master clock to remove the Phase Noise introduced by the internal workings of the 7350.
A further refinement is to generate an inverted version of this PDM (DSD) Data and feed into a Differential filter / Opamp, thereby remove the DC offset (half VCC) and Even Order distortion caused by unequal High / Low output impendence of the logic and also PSU modulation.
I’m sorry I no longer have the data sheet / App. Note on the CS4303 – they where in the Crystal semiconductors “Digital Audio Bible” the old thick Blue data book – which I seem to have misplaced in one of my many places of residence (I continually commute between Paris, HK, CZ and China)…
I’m not currently aware of any modern DAC IC’s which output a raw PDM / DSD / Bitstream data, however the PCM4202 ADC can output a 64fs or 128fs DSD stream – however its analogue input – not much help.
You could also look at the TDA1307 for a PDM Bitstream O/P - but it is not possible to bypass its internal digital filter - which sounds very poor (very bass heavy / no sound stage). But I also believe the 1307 is no longer manufactured - however it is younger then the SAA7350.
John
John
SAA7350 DAC
Hello John
I have heard that you can construct a low distortion DAC using this approach, I have heard that the THD&N can approach -110db with a all the precautions you previously mentioned. Have you ever approached these figures.
I am very interested in trying an experiment using the SAA7350 as the DSD stream and attempt to make this type of DAC. I get the impression they give a very good sound because of their simplicity all things being equal .You made some mention that this was not a simple DIY project but I am keen and proficient with building prototypes and can use SMD parts. I have built a DAC using the AD1853, and understand a little bit about laying out digital stuff and the need for proper continious ground planes. Is this enough. I also have some SAA7350.
Arthur
Hello John
Arthur
JohnW said:I worked closely with the guys at Pacific Microsonics...
Now you may have to talk with uncle Bill.
At Microsoft...
Re: SAA7350 DAC
I highest THD& N I've achived thus far is 128dB using an ASIC based modulator. However I''m just completing a layout using PECL logic - and I hope to improve upon this - measuring this level of performance is the greatest challenge.
If done correctly, the greatest problem you will have is finding a modulator which will not degrade the end results...
Carlos,
Yeh - like hell..... when I last heard they where working on video compression for dearest Mr Gates, and no longer interested in supporting the HDCD audio side of things....
John
PHEONIX said:I have heard that you can construct a low distortion DAC using this approach, I have heard that the THD&N can approach -110db with a all the precautions you previously mentioned. Have you ever approached these figures.
Carlos,
John
Re: Re: SAA7350 DAC
Hello John
You mention your modulator , why dont you use this in the CD player instead of the SAA7350, or is it an expense issue or am I missing something. What doe this modulator sound like compared to the SAA7350.
I was wondering what in your opinion is your best commercial DAC product you ever made, I can understand if you cannot tell us for commercial reasons.
Arthur
Arthur,
The cost of FPGA’s has reduced substantially – so it’s not really an issue of cost.
I’ve been working on Digital amplifiers since 1990; the modulator has been developed for Class D amplifiers. However – I work pretty much a “Vacuum” and need a “standard” to judge against – and I don’t just want any standard – I want the best I’ve ever heard! If my Digital amplifier cannot compete with this reference CD player and analogue Amp – then the technology is not yet ready…
Over the years I’ve listen to many production CD player / DAC’s, and to be blunt – they where all very poor in comparison to a good Turntable setup (remember I’ve spent my entire working life designing Digital products – so this is not some “Loose” statement).
However, the closet I’ve heard a digital product sounding to a turntable system was a dual SAA7350, PMD100, external I/V and discrete output stage design I cobbled together – everybody loved the sound of this system, never to be bettered by a digital product IMHO.
I can’t explain why – it was by no means the best measuring system (in fact it struggled to have a THD below 0.005%) – but we spent many a summer night listing to music with friends, drinking and eating. It was a system you could play in the background while talking and would never get annoying – towards the end of the evening you would find a room of 20 young people just sitting back and listening – and I’m talking about people who would never thick of listing to a Hi-Fi system. You could be in another room, and say – hey that sounds REALLY good!!!
I’m about to launch a State-of-the-Art Digital amplifier system, and I would like to have a reference CD player to use as a “yard stick”, but one that’s not full of snake oil and does truly come close to master tape – the memories of the dual SAA7350 system have never faded. It would also be one of the last chances I have to produce a “Reference’ CD only product – I guess that within the next 5 years the market for a CD only player will have shrunk to nil….
I need a CD transport for my digital amplifier – which I’ve designed, and it does not take much extra work to add a “DAC” board – the sound of the dual SAA7350 unit was to good to let it fade into history without allowing others to experience it – so, if I only sell 200pcs then its not about profit on this unit, but just so I can say - yes that’s the best CD player I’ve ever designed and heard.
Carlos,
I might have a source of SAA7350 – and this is not intended as a mass produced unit – maybe only 200 Pcs - I will sell as long as there’s demand….
John
Carlos,
John
JohnW said:Arthur,
John
Hello John
When you say dual SAA7350 was one chip used per side, how was this configured , each chip had its outputs paralled to achieve lower THD&N .
You also say external I/V and discrete output stage were these seperate I would have assumed they were the same thing, or did you implement a passive lowpass filter then feed the signal to the active output stage.
I think that the ouput stage could be implemented with direct coupled valve valve stage, with suitable low THD&N performance, but my first take will be silicon stage.
Is the reference power amp silicon or valve and of your own design.
Arthur
Arthur,
My all time “best” analogue amplifier (non Class D) was an amp based upon the Accoustat X type direct drive amp – driving CLSII ESL panels. My design was very heavily modified – but the OPS is basically the 6HB5 stage of the Accoustat X. These amps where just pure scary – the bass was so “Fast” and tight that when I first built the system, I was sitting on the very edge of the sofa waiting to dive across the room and pull the power plug - the Bass was just so powerful and “explosive”.
However – this would not be a fair comparison with my Digital amplifier – as the digital amp needs to drive the ML CLSIIz via a step-up transformers – and as with any transformer – they have a very large impact on Bass “speed” and well everything really…
I have a MOSFET’s based amp I designed with a Bryson type Nch & Pch OPS device for the upper and Nch & Pch lower pairs – bridged and with error correction circuit. Ironically this amp achieves distortion in the PPM range – and is the best sound analogue (ignoring the OTL ESL amp above) I’ve heard. It’s been my test amp for the past 15 years – a fine challenger for my Pure Digital Amplifiers….
The SAA7350’s where configured dual differentially (one for each channel), so inverted and non-inverted data was inputted from the PMD100 to each SAA7350.
The internal switch capacitor network was used (with due care taken with the Vref circuit), but with an external I/V which drove a balanced LPF – and summed with another discrete Opamp operating in Class A to form the output.
John
John
- Digital Source
- My new design ---DAC(SAA7350*2)
