| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hello,
When using an external clock for reclocking, there might be slight mismatch between the input master clock and the input data stream. Therefore occasionally, a stereo sample pair has to be reread or dropped depend on which freq. is faster. Does anyone know how this affects the sound? |
#2 |
Banned
It’s audible as a soft “tht” sound.
#3 |
Hi!
In my opinion external master clock used to reclocking MUST be synchronized with data clock (PLL circuit).How this will sound depends from length buffer memory which you use.You can also try ASRC but this will only 'glue' input jitter to datastream . Regards Martin |
#4 | |
If you look at some of the schematics that use external clock, the master clock pin of the CS8412 is configured as an input and the same clock is used to clocked the data into the DAC. I was reading the AD1896 and it seems like it uses ASRC by interpolating the input samples based on the external clock. I am not sure if this is supported by CS8412. |
#5 |
When I wrote about reclocking circuit , I thought about this :
In other case You you have to send clock signal back to the transport ,due to proper synchronism. Regards Martin |
#6 |
Image which I Attached is not avilable
Anyone know Why? Nevermind ,You can see it here: http://img60.exs.cx/img60/7831/reclock5lq.jpg Regards Martin |
#7 | |
I am still not sure if it will suppress jitter. Let say the MCLK coming out of the CS8412 has jitter. This clk is used to lock the MCLK_out which in turn clock the data out of the FIFO. I guess the goal here is to minimize the jitter of MCLK_out. Since MCLK is still jitter which is about 200ps as quoted on the data sheet, MCLK_out would still be jitter also. But I supposed MCLK_out jitter would be minimized and less than that since it is phase-locked to MCLK. And of course, the output path of the FIFO to the DAC is very small so jitter would be minimized also. |
#8 |
The advantage of using this circuit (PLL based) ,is one thing : PLL converting jitter (phase noise) into voltage noise (or digital noise in ADPLL) which can be filtered (in loop filter).In good PLL designs jitter reduction ratio is about 100.
More about PLL You can find here: http://httpd.chello.nl/~m.heijligers...l/PLL/PLL1.htm My favourite example : http://focus.ti.com/lit/an/scaa067/scaa067.pdf See page 5 Regards Martin Ps.Sorry for my poor english
#9 | |
Result really sounds great. I tested it with my ears on signals showing a different kind of jitter. Some signals I used were so bad that I could clearly see the jitter in the eye-diagram (+- 10%). At the output of the unit you really hear NO difference between signals with or without jitter!! Beyond this the advantage is you could use a extremely low jitter oscillator (no PLL or VCXO) to clock the output stage of the AD1896 and the D/A. In my opinion the AD1896 is the best chip to forget about the jitter problem. Charly |
| Thread Tools | |
| Is the PCM-61 Dac are I2S or EIAJ data input ? | gaetan8888 | Digital Source | 2 | 7th August 2007 06:08 PM |
| External input to filter module? How...? | njosnari | Parts | 0 | 10th July 2007 12:46 AM |
| Aleph60 input stage mistake! Pilot error | amplitone | Pass Labs | 2 | 5th November 2005 02:27 AM |
| Lots of freq response data of PA drivers (link) | Elias | Multi-Way | 0 | 21st December 2004 09:25 AM |
| Reclocking data line | tonitze | Digital Source | 5 | 11th July 2003 05:20 PM |
| Page generated in 0.49898195 seconds (9.96% PHP - 90.04% MySQL) with 11 queries |
