Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th March 2005, 09:20 AM   #1
Default op275 upgrade
My Dac has two OP275 op amps that I''d like to upgrade to some thing better. What would be a nice drop in op-amp to replace these reliable buggers. Thanks.
justpoor
Old 4th March 2005, 09:34 AM   #2
John Hope's Avatar
Default OP275 replacement
Hi
I'd suggest you consider the Burr-Brown (TI) OPA2134. I use them as 1st choice in all new designs. Available in all the usual packages. Check them out on the TI website.
John Hope
At Spes Infracta
Old 4th March 2005, 11:46 AM   #3
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
I'm just trying out the OPA2132 in my CD player... very natural sound... much better than OPA2604. Like many do, and I have done now, why not fit a socket so you can audition different ones easily? It's a good move
Old 4th March 2005, 07:46 PM   #4
John,
I will try that - thanks for the suggestion.
SimontY ,
"why not fit a socket so you can audition different ones easily? It's a good move"
It's a great idea. I will order the socket along with OPA2132. thanks.
JustPoor
Old 5th March 2005, 01:20 AM   #5
BrianL is offline BrianL  United States
Let me know what audible differences, if any, you perceive
between the OPA2132 and OPA2134.
bel
Old 5th March 2005, 03:09 AM   #6
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
The OP275 is already an excellent op-amp.
Lemme know how this goes.
Old 5th March 2005, 07:57 AM   #7
Before I swap them in I just want to make sure that I can just plug and play the OPA2132 and OPA2134 in place of OP275 in my Audio Alchemy DAC V1.1 without any modification to the power supply, etc.... right.
Will put in an order for these op-amps tomorrow. Thanks.
Old 5th March 2005, 08:22 AM   #8
Yup. They're pin compatible. If in doubt, look at the datasheet and make sure that everything lines up. I would go for the 2132 or maybe the AD726. Both of them sound pretty good (I have an AD726 in an Audio Alchemy DDE 1.0 that I just picked up off the trading post here, sounds pretty dang good and still goes for $7ish on Digikey).
Old 5th March 2005, 08:49 AM   #9
adinica is offline adinica  Romania
I have tried op275gp and opa2134pa in a sony cdp-xb740qs over njm2114d standard, but with poor results. Then i have tried opa2132pa and the sound is much better, warmer and with smoother in the treble, if a tad veild ( BB op-amps sound character).
opa2143 is much drier than op2132, but better than opa2604.
All the best!
Old 7th March 2005, 12:06 AM   #10
georgehifi's Avatar
Send a message via MSN to georgehifi
I used to love the OP275 far smoother and more musical than say a NE5532, i've tried a lot of different drop in replacements, and the AD825 is by far the best, but it only comes in SMD and it is a single not dual, so it needs 2 per channel on blackdog adapter boards. Go the extra yards for these you will never look back.
http://www.soundlabsgroup.com.au/com...ules.htm#ad825
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
OP275 opamp replacement help. Glen1 Digital Line Level 26 31st March 2012 07:58 PM
Input oscillation (Pin2) OPA2604 & OP275 grievousangel Solid State 11 5th August 2008 06:36 AM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
Wtb:op275 vadimgal Swap Meet 0 10th October 2007 12:20 AM
Page generated in 0.10190 seconds (76.48% PHP - 23.52% MySQL) with 10 queries
