| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi Very body,
Does anyone has the PS Audio Untralink 2 DAC schematic diagram or service manual? I need the help for repairment of it. It always unlock many weeks ago and now has no sound. Thanks:
chokh |
#2 |
Hi Chokh,
Unfortunately not even PS Audio has the schematic for the Ultralink II. I have one that works fine, but have been having problems with my Lambda Drive for years and tried to get any information I could find. I thought it would be wise to try to get service info on all my PS Audio gear before I have serious problems - no such luck though. The Ultralink, and Lambda series stuff was all built by Theta Digital, but sometime after the two firms split all of the documentation for this product line was apparently lost. When PS Audio went through its bankruptcy and before the current principles took over someone apparently trashed all of the existing product information. Its a sad story, but even worse is the fact that Philips sold them and a lot of other outfits CDM9pro mechanisms for use in very expensive cd players and transports and discontinued the drive shortly thereafter, knowing full well that these devices weren't intended to be throw aways, and that their crummy mechanism was not all that durable. I honestly had less trouble with a 15yr old Sony with about 5K hours on it than I have with the mechanism in the Lambda which is roughly half as old and has maybe 1K hours on it tops. Makes you want to stick to the high end offerings of majors (HK mostly) and stay away from all small manufacturers. |
#3 |
I am also trying to sort one out. I have sorted several Theta Data Basic units (same thing) by doing the swing arm optical swap from CDM9/44 into the pro with great success. The lambda I have is stumping me though....
Guillaume |
#4 | |
I contacted PS Audio a few months ago and they sent me a copy of the schematic for my original Digilink DAC. Give them a call. Best, Paul |
#5 |
I have talked to people at PS Audio and Theta Digital about the Ultralink II and the Lambda Drive and they have no information as I indicated above. Copies of the owners manuals are all they have. They do have the schematic for the original ultralink as do I, however it is quite different from the Ultralink II.
#6 |
Hi kevinkr,
What; they (and you) have the schematics for the Ultralink I? They said me they don't have those. Could you email me those please? My Ultralink I has started to so show some age and is loosing the lock sometimes. So at least I'll replace the lytics and see if that does it. |
#7 |
I can email you the schematic, note that it is huge - for some reason even though it is a pdf file it is about 11MB in size. You will probably need a gmail or yahoo mail account to be able to get it.
Kevin |
#8 |
hi tubenut,
I meant to reply to your question about the problem with my lambda - well it is really two fold, but the symptom is exactly the same in both cases : the spindle motor simply refuses to spin up. About every 3 - 6 months I have to disassemble the drive and clean the low profile tin idc connector on the mechanism as it becomes intermittent - sometimes I think there might be more to it than this, but have not been able to identify any issue. The obvious solution is to replace the ribbon cable assembly with something better, provided that that is the only real issue, and I am not sure it is.. Relatively frequently (say every week or two) I have to cycle the power switch on the back panel to do a hard reset. The reason for this is that the spindle motor refuses to spin up and the disk is not read when the drawer closes.. Usually, but not always holding down the play button on the lambda front panel results in an error message and then disk plays. Sometimes nothing happens except a loud clunk and the error message. Cycling the power clears the problem temporarily or even for days or weeks at a time. The power here glitches relatively infrequently so it seems that the lambda mechanism may have a reset or other issue due to line transients or the instruction bus clock and data get out of sync over time. I have owned my Lambda almost since new and know its previous history.. It is a low hour unit and I have owned it since early 1997, and have not used it over much. I talked to Philips about getting technical data on this drive and despite the fact that it is obsolete they are unwilling to provide me with any information.. I have to say I now have a very negative impression of the quality of Philips products, and of their support policies. I will NEVER and I mean NEVER purchase a cd player or drive that contains a Philips mechanism again. IMHO their stuff is bottom of the barrel when it comes to reliability. (See my comments about the CHEAP Sony I recently gave to one of my friends. It's design is somewhat older than the cdm9pro mechanism but not by much, and very much cheaper, but it still works and has never missed a beat.) Companies like HP/Compaq/Dell and others publish the complete maintenance/service documentation to their products online when they are obsoleted - which makes it almost a snap to keep old machines alive. I love the PS Audio stuff, it was amongst the best in its time, but I don't feel that I should have to throw this drive away in a couple more years because I can't get any parts or information for it. Unfortunately PS Audio is basically a different company today, having been through a messy breakup and bankruptcy - and they have been as helpful as possible under the circumstances. (Kudos) It's not like it was a $100 cd player. I am simply trying to protect my investment.. Kevin Edit to correct date typo |
#9 |
Sure I have some that can handle a file that big. One at gmail for example.. I can't email you the address because you have email disabled, though. Shoot me a message so I can send you my email address. Thanks!
#10 |
Hi Netrunner
Your email is disabled too.. I am unable to send you email.. I am direct.heated@nospam.gmail.com remove nospam to reply Kevin |
| Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? | tiefbassuebertr | Solid State | 43 | 22nd January 2012 12:50 PM |
| For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp | tmort | Swap Meet | 5 | 27th June 2009 12:29 AM |
| Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D | jaimegmr | Car Audio | 0 | 5th May 2009 06:39 PM |
| Need schematic for PS Audio Ultralink -2 DAC | vadimgal | Digital Source | 0 | 22nd June 2007 11:50 PM |
| Page generated in 0.11917 seconds (81.03% PHP - 18.97% MySQL) with 10 queries |
