Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th February 2005, 12:50 PM   #1
Default PLL 3rd Order Passive Loop Filter, calculation arguments
I will be the first to admit that the PLL circuit as well as the LPF in the schematic is not of my design. It is copied from Mark Heijligers' DAC, although implementation is different. To be put to use, it needs, however, to have it's LPF recalculated. The operation frequency of the original circuit is 705KHz, I want mine to operate at 2.8224MHz (64*44.1KHz, SCK output of CS8412).
To recalculate the PLL 3rd Order Passive Loop Filter, I need the following 7 arguments, and I was hoping some members on this forum could help me out..
They are:[list=1][*]Maximum output frequency from the VCO [*]Desired bandwidth of the PLL[*]Reference frequency of the loop (I guess this will be the 2.8224MHz...)[*]Desired phase margin of the PLL (degrees, 30-70)[*]VCO tuning voltage constant (MHz/Volt)[*]Phase detector/charge pump constant (mA/2*pi*rad)[*]Desired attenuation from the low pass filter (dB)[/list=1]
The VCXO to be used is a Tent VCXO... 11.2896MHz... divided down to the 2.8224MHz used in the PLL.
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
Sime filter calculation help needed. Nordic Parts 20 15th November 2006 02:42 PM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Passive - Active Pre-Amp arguments alaskanaudio Everything Else 3 26th December 2001 01:04 AM
Page generated in 0.07151 seconds (72.06% PHP - 27.94% MySQL) with 11 queries
