| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#41 |
4real..........
are those muting transistors .......? get rid of them and be very suprised at how much they hold back this player |
#42 |
iamwhoiam, All
Sorry if this sound a dummy question. I was aspired and try to do some mod on my newly bought CD5001. My 1at attempt will be to replace the 6 bipolor coupling to ROE electrolyte non-polar with 0.1 bicap. It should be the simplest upgrade and have audible difference I guess. However, I got stuck at the beginning. Could you advise how to unlock the ribbon cable between the mainboard and the CD drive (also, those two ones between the m/b to the control panel PCB? Thanks. |
#43 |
Finally, I've done it.
#44 |
just be careful with the ribbon cables ......
the push in one needs to be lifted square and fitted the same way. the others with the clamp are easy |
#45 |
Due to the overwhelming response from people requesting the service manual, I have re-uploaded it here:
http://www.ukns.org/uploads/diy/cd5400.zip (compressed with Winrar in zip format). Might not work in XP, but will definitely work in the latest version of winrar. RE: 4real Thanks for the input, I guess I'll take a look and swap those capacitors for the DAC output caps and see what it feels like. Did you find the new opamp improved much of the detail? edit: Sorry for lack of replies, I haven't used the CD5400 much since. It's now rigged up to my parent's AV system as a better-than-dvd-player-cd-player. Hmmph lol. |
#46 |
RE: 4real
Just to reiterate for those who want to attempt this mod. In my original posts I replaced C210/C310 caps. This is not needed as 4Real has found out. So just short them out with a jumper. DC actually comes from the DAC. Which are C201/C202 (left channel), and C301/C302 (right channel). So replace them with audio-grade polyprops ![]() RE: Muting capacitor mods Remove Q404/Q405/Q406/Q407 |
| Thread Tools | |
| Marantz CD5400 - stuck cd drawer | Bobby_MC | Digital Source | 0 | 16th April 2009 04:56 PM |
| Modding a Marantz CD40 | joydivision | Digital Source | 29 | 29th February 2008 06:35 PM |
| Marantz CD5400 clock replacement | 4real | Digital Source | 83 | 11th March 2006 09:53 AM |
| Marantz CD5400 Output Stage | iamwhoiam | Digital Source | 0 | 25th January 2005 10:22 PM |
| Marantz CD5400 Tweak | dh001 | Digital Source | 0 | 18th December 2003 12:01 PM |
| Page generated in 0.14385295 seconds (79.25% PHP - 20.75% MySQL) with 10 queries |
