Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st February 2006, 11:43 PM   #31
Hi 4real,
I did put 'cd5400 service manual' 'cd5400.rar' and 'cd5400.pdf' into Google first before posting and drew a blank, honestly. Thanks for the link.
Jon
Old 21st February 2006, 11:46 PM   #32
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally posted by 4real
Edit: what the hell happend here A whole bunch of posts has suddenly gone...!
Edit2: Ah, some split the threads.
Yes, I split the thread. It seemed to me that the clock modification was a thread in its own right.
I'd offer to email the manual, but it's an enormous file (45MB).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 22nd February 2006, 08:57 AM   #33
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
Originally posted by iamwhoiam
A Polypropylene foil 8uF "Audio Grade" by LCR to replace the Elna Starget 10uF I originally had in there. Thing's huge and had to mount off board. [/B]
I hope you realize that those output caps are not the only ones in series! After the dac each channel has two 10uF caps in series as well!
Old 22nd February 2006, 08:11 PM   #34
gfinlayson's Avatar
I've zipped the 5400 manual and dropped it here. It should be a bit more manageable at 8.44 MB. It should also download reasonably quickly as well - it took only 16 seconds on my connection.
Old 4th March 2006, 08:19 AM   #35
When I was checking the layout of the lowpass filter I dicovered something strange.
Resistor R201 (R301) is connected to R202 (R302)with capacitor C211 (311). According to the application note from Cirrus this capacitor should be connected to "earth".
http://www.cirrus.com/en/pubs/appNote/AN048Rev2.pdf
This application note shows the filter suitable for the CS4392.
Has anyone noticed this??
Old 4th March 2006, 10:22 AM   #36
Oh well, I guess, you should check how it is connected on the real PCB, since this manual isn't really acturate at times.
Old 4th March 2006, 02:57 PM   #37
I did.
Anyone else?
Old 11th March 2006, 05:20 PM   #38
Originally posted by Max the Great
Anyone else?
I might be on to something here maybee. I shorted all the six caps in the signal way, to check the sound without the caps. Well it improved, but guess what: I measured about 250 mV of DC on the output . I'm going to check where this comes from next week. It could be the DAC, or the filter/buffer... If it's the buffer, that would indicate that there is something wrong with the design I guess, I can't imagine that those 250mV is intended. I changed the opamps to AD8620's though, but that should not matter I guess...
Old 14th March 2006, 08:33 PM   #39
Well, it turns out the DC comes from the DAC caps. If you leave them in, and short the output cap, you get no DC at all on the output!
So iamwhoiam, those huge LCR caps are not needed at all! Also, you gain more if you replace the DAC caps, as I did:
(never mind the cam)
I Replace all four 10uF elcos with 5.6uF 400V 5% Audyn MKP-QS caps, and shorted the output cap.
Old 21st October 2006, 02:58 AM   #40
pwan is offline pwan  United Kingdom
I'd like to have minimal touch on my CD5001.
A). What is the simplest but most audibly effective in term of sound improvement?
B) Will only change those 6 audio coupling cap (C201,C202, C301, C302, C210, C310) help? Thanks.
C). Will the electrolyte Blackgate N series (~ US$6 each) be worthing?
Thanks.
Modding a Marantz CD40 joydivision Digital Source 32 11th March 2011 06:55 AM
Marantz CD5400 - stuck cd drawer Bobby_MC Digital Source 0 16th April 2009 04:56 PM
Marantz CD5400 clock replacement 4real Digital Source 83 11th March 2006 09:53 AM
Marantz CD5400 Output Stage iamwhoiam Digital Source 0 25th January 2005 10:22 PM
Marantz CD5400 Tweak dh001 Digital Source 0 18th December 2003 12:01 PM
Page generated in 0.12017 seconds (82.27% PHP - 17.73% MySQL) with 10 queries
