| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Heya,
Just curious -- is there anywhere else besides Newark InOne that I can purchase a CS5361 analog to digital converter chip? I've tried requesting samples but havn't received any responses (or samples..), nor can I find an online site other than Newark InOne that sells them. I don't really want to use Newark InOne because $11 just for shipping and handling is a bit ridiculous... Thanks! Regards, Matt |
#2 |
If u try to request samples direct from Cirrus,is not that easy
#3 |
apparently so... I was looking through my other samples however and saw that I received a DAC chip from Cirrus.. I wonder why they're being so difficult about the CS5361
#4 |
Have you tried calling them or emailing them instead of using the sample request form? Might help if you explain that you actually want to pay for it but can't find a dealer
![]() /U. PS: Just out of curiosity, do you have a schematic of your design you can post? i'd be very interested in seeing it
#5 | |
![]() Cirrus provides an analog input buffer schematic for the CS5361 A/D chip. It's got balanced inputs so hopefully I can go and buy some decent recording mics (Im thinking of probably some SM57's, but if I can come up with the cash I'll buy a pair of SM81's) Here's that schematic I'll adapt this schematic to add phantom power ![]() As far as interfacing this with the uC (Microchip PIC18F2455) I'll run the A/D in master mode (generating it's own clock pulse) then the PIC will read in the clocked data and use it's onboard USB interface to pipe the data back to my computer. |
#6 |
Ok, thanks. If you haven't already, then have a look at the PCM1804/OPA1632 combination from TI as well (download the datasheets). That's what I've been considering, but I don't really have time to work on the project atm
![]() /U. |
#7 |
I took a look at the PCM1804 datasheet and ordered a few samples which are being UPS second day aired to me as I type
It's certainly easier to get this than the CS5361, however the package is kind of small and might be difficult for me and my almost non-existant soldering skills to deal with. TI doesn't really give a very clear schematic detailing how to hook the PCM1804 up (what capacitors to use to filter the input voltages, etc.. I'm not too experienced with this type of stuff) Should be interesting though. I'll keep you guys updated. I'm still not sure if I'm going to use the CS5361 or the PCM1804 yet. |
| about data reading from i2s protocol based CS5361 | sukhdeep | Digital Line Level | 0 | 29th November 2008 07:07 PM |
| 24 bit 356 kHz DA converter | martioz | Digital Source | 10 | 13th December 2004 08:01 AM |
| diy A/D converter | elperopu | Digital Source | 2 | 25th May 2004 06:15 PM |
| 24v to 12v converter | moi | Parts | 5 | 15th September 2003 12:47 PM |
| Page generated in 0.09166 seconds (73.11% PHP - 26.89% MySQL) with 10 queries |
