Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th February 2005, 09:06 PM   #1
Default who listened to DSD1792?
Have you listened to DSD1792 (or compared the sound to TDA1541 or PCM56 and other good sounding DACs)?
The measurement is excellent but is-it good sounding in a CD player?
Vincent
http://vincent.brient.free.fr/main.htm
Old 22nd February 2005, 04:35 AM   #2
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
The Denon DVD-2900 & DVD-2200 use the DSD1792 - might be worthwile hunting down reviews on these machines.
Also this thread PCM1792 and DSD1792 with 132dB SNR
John
Life shouldn’t be take it too seriously, you will not come out alive anyway…
Old 22nd February 2005, 04:41 AM   #3
JohnW's Avatar
Also Musical Fidelity use the DSD1792 in there Tri-Vista 21 DAC and SACD player
John
Old 22nd February 2005, 05:27 AM   #4
relder's Avatar
Send a message via Yahoo to relder
I can't answer your question yet, but I plan on using one to replace the 1791 in my Pioneer 563 mainly since it appears to respond to the same register control codes as the existing 1791 (a voltage out DAC). I'm then planning on a Pass D1 for the I/V. I just received the 1792 in the mail last week. I'm also contemplating a discrete DSD output w/ no DAC at all (maybe, still got some thinking to do about that. )
So I might be able to answer your question in 6 months or so when I finish the project!
Rob
Old 22nd February 2005, 06:38 AM   #5
JohnW's Avatar
Some reviews say that the DVD-2200 uses the DSD1791
Old 7th March 2005, 06:51 PM   #6
TNT is offline TNT  Sweden
TNT's Avatar
"I'm also contemplating a discrete DSD output w/ no DAC at all (maybe, still got some thinking to do about that."
Interesting - mind sharing some more of this?
Old 7th March 2005, 09:06 PM   #7
relder's Avatar
I basically plan on taking the DSD bitstream, amplifying it (via just mosfets used as switches) and filtering it, if it's as simple as that. Sony used to make a big deal as to how simple it is.
Some things I'm not sure of:
1) The DSD bitstream is encoded in such a way that I can't do that, I.e. it's not the PWM signal that a DAC gets but some other packetized format. Another thread seemed to suggest that the bitstream is indeed the DSD PWM signal that can be simply filtered to get output, I'm assuming that's the case for now.
2) How much amplification is needed to get the typical 2V output of a CD player. Theoretically the output of a filtered 1V PWM signal could get up to 1V I think (not an EE in my day job, will have to hit the books to know what's correct) but I'm guessing that real encoded signals don't use all that bandwidth, i.e. a 0dB signal is less then that, so I need to figure out the details on that, probably via experimentation if I can't find any docs.
I don't want to amplify the filtered signal later on as I plan on just using the source follower of the Pass/Wayne D1 to buffer it, which will be relay switched between the D1 I/V converter and the discrete DSD. Hence the desire to figure out what voltage the switching mosfets need to be at.
At least that's the plan in my head.
Rob
Old 7th March 2005, 09:15 PM   #8
TNT's Avatar
I'm sorry that I cant help You on the details - hopfully other may have insigth, but please keep us posted if You try this !
Old 9th March 2005, 05:27 AM   #9
Htguy is offline Htguy  United States
Default Denon 2900...
The denon dvd 2900 used the BB 1790 dac Not the BB 1792 dac. (Denon had burr brown make the 1790 just for them)
God bless...
Mark
Anyone listened to 14bit NOS ? el`Ol Digital Source 4 12th January 2009 07:04 AM
Replace DSD1796 with DSD1792 joonho75 Digital Source 0 30th March 2008 02:15 PM
Anyone listened to these speakers? Konnan101 Multi-Way 4 28th December 2003 11:57 AM
Best horns I ever listened to Salas Multi-Way 0 29th June 2003 01:14 AM
PCM1792 and DSD1792 with 132dB SNR sonnya Digital Source 68 25th May 2003 05:19 PM
Page generated in 0.10953 seconds (79.20% PHP - 20.80% MySQL) with 10 queries
