Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th February 2005, 10:25 PM   #1
Hybrid fourdoor's Avatar
Default Problems adding Digital Out to Laserdisc player (LC78621 chip)
Trying to add a digital output to a Laserdisc player. The datasheet for the chipset says pin 56 is DOUT. So I ran a wire from pin 56 to a TTL=>Coax circuit, however when I use a multimeter the voltage coming from the chip is only like 2.9V....shouldn't it be ~5.00V?
Needless to say I'm not getting any output.
I didn't do anything to the chip, as I don't see like a DOUT enable pin or anything.
Any ideas?
I enjoy my organic shapes.....
Old 25th February 2005, 03:46 AM   #2
inn is offline inn  Singapore
hi, you may try the following which I have done to my Onkyo LD player.
LC78621 75ohm coax CS8412/4
pin56-DOUT ---------------------------> pin9-RXP
common gnd ---------------------------> pin10-RXN
(find any gnd jumper next to LC78621)
I suppose you must have missed out the gnd
Old 25th February 2005, 05:37 AM   #3
Banned
Default Any ideas?
Yes. For starters:
You can't measure a digital signal, probably 2.8 MHz or so, with a multimeter.
Jocko
Old 25th February 2005, 07:13 AM   #4
A 8 is offline A 8  Sweden
It would probably be something like that measured by a multimeter even if it was working so it really don't indicate anything.
Dout can be muted, details in the datasheet. The other issue could be how you've connected things, dout is made to drive a transformer direct again see the datasheet.
Old 26th February 2005, 01:59 AM   #5
hi A8, do you mind sharing how could I disable the MUTE function in this chip....I know very little in digital world
Thanks in advance!
PS : I connected the DOUT to CS8414 via 1:1 Pulse Trans in my external DAC.
Old 26th February 2005, 07:43 AM   #6
inn,
I know you can read, its in the datasheet. If you cant find it just do a search for dout.
/Michael
Old 26th February 2005, 12:10 PM   #7
Heres the inspiration I used. The only thing I could think of was the mute pin.
Old 26th February 2005, 03:15 PM   #8
The datasheet says 0.5vpp for dout so it is probably too low for your 74hc04 to detect any pulses.
For testing you could connect dout via a cap directly to spdif in and see what happens.
Old 27th February 2005, 05:57 AM   #9
why do you need 74hc04 in the first place?
I connected the DOUT from LC78621 with coax cable directly to my digital receiver CS8414 via a 0.1uF wima mkp cap and 1:1 pulse trans (all in my DIY DAC). No problem with the output level.
coax
LC78621 pin56 (Dout) --------->0.1uF---->pulse trans--->cs8414
LC78612 gnd -------------------->DAC gnd
coax schield
Old 30th January 2009, 08:30 AM   #10
diyAudio Moderator Emeritus
I'm trying to make digital SPDIF out for a Denon CD player. This unit has no SPDIF or Optical digital out.
The IC is LC78621.
From the scope I see pin56 (Dout) is giving nothing, 0V.
How can I enable Dout to give digital out? I cannot understand post by A8 above.
Wanted: Laserdisc player (UK) ben12345 Swap Meet 1 17th February 2009 07:59 PM
Adding a pre out before the chip meepers Chip Amps 5 8th November 2008 12:16 AM
Pioneer CLD-2950 Laserdisc Player richardsymes Digital Source 3 20th August 2007 11:14 PM
Adding digital out to a CD player with only PCM! Destroyer OS. Parts 0 4th June 2006 09:51 PM
Adding Digital Input to CD Player -> low cost DAC for PC Brent Welke Digital Source 1 2nd January 2005 04:57 AM
Page generated in 0.10467 seconds (78.33% PHP - 21.67% MySQL) with 10 queries
