| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am messing around with the Crystal CS8412 digital reciever chip, trying to build a decent SPDIF input stage for it and realizes this task is not as trivial as it first appeared to me...
After reading through an informative thread on the subject, I could not help myself from stopping again and again reading through WMS's post at http://www.diyaudio.com/forums/showt...7860#post27860. This definitly looks like the way to go, and the 6111 triode idea melted me.... Now, when using the 6111 tube in place of transistors as WMS suggests, I would have to set it up as cathode follower with coupling capacitors wouldn't I? Also, Partsconnexion has a Aes-EBU-tranny that might be a good alternate to the Lundahl LL1566 I have, since it appears (judging by it's picture, i have to check this) to have centertap on its primary, wich might be beneficial to connect to ground reference in a balanced scheme? Could anyone help me get somewhere with this? Any thoughts or ideas? Here is a copy of the circuit MWP suggests, but using transistors...: |
#2 |
Banned
Why do you think that you need to amplify it? The output is supposed to be 0.5 V p-p, not 50 V p-p.
Jocko |
#3 | |
Edit: Also, the CS8412 chip will have no problems handling a higher, say 3V p-p signal (example out of the blue), with it's self-biasing feature? |
#4 | |
Apparently, Harry have had good experiences using the '86, so I thought it was a somewhat safe and way easier approach than reclocked flipflop or other suggestions i've seen.. Here's what he says;
#5 |
Banned
Uh..........the output is CMOS level..............5 V p-p. You need to reduce it, not amplify it.
As for reclocking F-F..........put it in front of the '86, and only use one ouput. Yeah, too good to give away for free, but what the hey............ Don't use the Lundahl. They make good audio transformers, but SPDIF onrs are totally different. I would not use them. Or any designed for AES-SPDIF conversion. Or 2:1 ones, either. Jocko |
#6 | |||
Thanks for your reply, Jocko.
Edit: PE-65612 pdf @ http://www.elfa.se/pdf/56/05655055.pdf edit: edit: BTW they are pulse trannys... |
#7 | |
I'll rather ask wether OPA2134 could be a suitable buffer... got spares of these too...
#8 |
Banned
Yes, he wants to keep the impedance constant, but I bet that he does not have a TDR. I do...........
I never tried adding a follower, but then I have other ways of isolating the driver from the line. Those cheap Chinese transformers are ok. A cheap version of a Schott, that was good. Lundahl............stick with his audio transformers. I would not waste a good part of the SPDIF output. It has to work at 2.8 MHz, and pass at least the fifth harmonic. Still want to use a good audio part there?????? Yes, reclock on the TX side. On the RX side, you need to come up with a seconadary PLL, and use that to get the recovered clock. (I have a buddy that sells one, but it is not cheap. I use one, but I need a good reference system.) Jocko |
#9 | |||
![]() Quote:
![]() Quote:
Let's assume for a second that my setup will be the reclocked 74 flipflop, into the 86 as digital phase splitter, resistive network, opamp buffer, then the tranny...Would I feed the 74 on the TX side 2.8MHz, and then 44.1KHz for CS8412 FS output on the RX side? If so, could this be done as simple as using one clock, say 11.289MHz, and use a binary counter or other suitable logic to divide by 4 and 256? Sorry if I ask very dumb questions here.. New*cough*bee
#10 | |
DIY !
Arne K
Ars longa, vita brevis |
| SPDIF on cdrom to SPDIF on Digi Crossover | davidallancole | Digital Source | 0 | 11th January 2007 03:26 AM |
| cdrom spdif quality / sound card spdif | metebalci | Digital Source | 0 | 2nd September 2006 07:16 PM |
| spdif out to double spdif in | balthazard | Digital Source | 0 | 1st March 2005 06:52 AM |
| SPDIF: VCC / SPDIF which way round? | rogercameron | Digital Source | 6 | 18th April 2004 10:29 AM |
| DIGI balanced AES/EBU -> SPDIF Coax | meta | Digital Source | 3 | 26th May 2003 05:51 PM |
| Page generated in 0.13322 seconds (82.13% PHP - 17.87% MySQL) with 11 queries |
