| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Thanks for all your help. Just to close out the thread, I thought I would post what I finally did.
I tried bypassing all the output circuitry, in other words, op amp output through a single PP cap straight out. Difference was negligible. I then added the Toslink output. I did wind up mucking around with the circuit a bit, but I am not completely sure if it was a connection mistake or the current FO TX requires different supporting components. I used 330R resistors and both 0.1 uF and 18 pF caps and it works regardless. As I mentioned above, the part to buy is Sharp GP1FA514TZ. The bass is great! It is so amazing to not have my sub plate amp go into sleep mode when I watch TV! ![]() As for coax output, I was satisfied with performance from the FO, so I just switched my DVD to coax from FO cabling so that I could connect everything into the smallish number of inputs in my receiver.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#12 |
I'm looking to buy a few Sharp GP1FA514TZ FO transmitters. anyone know who sells these?
Thanks |
#13 |
#14 |
I'm having a "discussion" with a friend about the modifying a 3100 for the optical output. Here is the question:
Will the 3100 output Dolby 5.1 (AC3) when there is program material encoded in 5.1? If not, what format would be output? Dolby 2.0? ProLogic? Thanks |
#15 | |
It is just a 2 channel stereo PCM output.
| DIY lo-fi speaker element | Mursu | Multi-Way | 15 | 29th March 2009 03:44 PM |
| A very interesting loudspeaker element | pelanj | Multi-Way | 2 | 13th August 2008 03:22 PM |
| L as last filter element? | rman | Tubes / Valves | 2 | 4th June 2008 03:31 AM |
| What speaker element is this? | tian | Multi-Way | 12 | 9th April 2008 05:43 PM |
| Microphone Element recommendations? | Upionics | Parts | 2 | 14th August 2004 11:23 PM |
| Page generated in 2.96689 seconds (3.32% PHP - 96.68% MySQL) with 11 queries |
