Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
What is this circuit element?
Old 9th February 2005, 02:22 AM   #1
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Default What is this circuit element?
Here's the background: I am starting a multi-pronged attack on my satellite receiver (Bell 3100) to get better quality audio out of it. The lack of bass has been driving me crazy and now it has turned to obsession. The digital part is under control and I have parts on order and know what I'm doing there. Now the analog:
The attached schematic is for each channel of analog output. That is as much as I could trace out before I got lost. My question is, is the circuit acting as a high pass filter in any way? Can I do away with any part of it?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 9th February 2005, 04:51 AM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
NO matter how bad is the bass of your receiver it is certainly not because of filtering. Your circuit is mostly a low pass filter but the 47uF will have some effect on low frequencies. Not enough circuit for anything useful. Stop being lazy
Old 9th February 2005, 04:44 PM   #3
leadbelly's Avatar
Originally posted by analog_sa
Stop being lazy
I can assure you that this is the opposite of being lazy. I am trying to add optical & coax digital outputs PLUS muck around with the analog output. The problem is that since this is new territory I can never know how much bass is actually in the source signal so until I try a bunch of things I can never know if something will work.
I am baffled by the polarized cap. I suspect that the audio signal entry point is the junction of R2 R3 C2, but could it actually be serially through C2? What other use would C2 likely have?
Old 9th February 2005, 04:53 PM   #4
analog_sa's Avatar
I would guess it's through C2. There has to be a coupling elco after the output opamp.
Old 9th February 2005, 05:15 PM   #5
leadbelly's Avatar
I found this:
http://www.diyaudio.com/forums/showt...623#post546623
Very similar output stage. I guess it must be some ubiquitous commercial design. I'll have to keep searching for a quick-and-dirty improvement to it.
Old 9th February 2005, 06:51 PM   #6
leadbelly's Avatar
Information overload.....so many designs out there....
So if I do manage to trace out more of the circuit including the op amp driving the output, any recommendation for an easy improvement?
Old 10th February 2005, 02:07 AM   #7
thomas997 is offline thomas997  Canada
thomas997's Avatar
Adding an optical output to the 3100 should not be too difficult. The sound will be clearer, less noise, and should have more bass (will still be stereo though).
Parts needed:
425-1100-5-ND X 1 = (TRANSMITTER FIBER OPTIC 8MBPS)
311-100ACT-ND X 1 = (RES 100 OHM 1/8W 5% 0805 SMD)
311-1141-1-ND X 2 = (CAP .10UF 25V CERAMIC X7R 0805)
Optical jack location
Solder locations picture
Instructions:
- remove solder from 3 spots shown
- solder on three smaller components 2 capacitors and one resistor
- solder in Toslink transmitter
- last drill hole and reassemble
(source: wlo from Maestra forums)
Dont know about the coax though.. you could always use a convertor box if it was really necessary.
btw let me know if you figure out any ways to improve either the analog sound out or the picture quality.. My receiver has some crappy picture quality problem. Most likely due to the lack of cooling and chips overheating.
Old 10th February 2005, 05:26 AM   #8
leadbelly's Avatar
Thanks. I know all that. Actually, your information is a bit out of date. The GP1FA511TZ is obsolete and Sharp's current replacement is the GP1FA514TZ.
Old 10th February 2005, 06:04 AM   #9
leadbelly's Avatar
Bump.
I managed to trace out this much more:
Old 11th February 2005, 10:47 PM   #10
carlosfm is offline carlosfm  Portugal
Banned
1. Change that LM358 for something better (almost anything is better than that ).
2. Change R2 for 50R.
3. Remove C1.
4. Remove R1 and put a wire link.
5. Enjoy.
Btw, the lack of bass must be the LM358 and/or something behind it, like an ultra-cheap dac.
What is this circuit element?Hide this!Advertise here!
DIY lo-fi speaker element Mursu Multi-Way 15 29th March 2009 02:44 PM
A very interesting loudspeaker element pelanj Multi-Way 2 13th August 2008 02:22 PM
L as last filter element? rman Tubes / Valves 2 4th June 2008 02:31 AM
What speaker element is this? tian Multi-Way 12 9th April 2008 04:43 PM
Microphone Element recommendations? Upionics Parts 2 14th August 2004 10:23 PM
Copyright ©1999-2017 diyAudio
