| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#61 |
Hi
the application note for the pcm63 shows pins 5 and 6 bridged - no indication that it is a cap or resistor, etc - can the pins simply be bridged w/ copper wire? Thanks Bill |
#62 | |
If the original design has 5 & 6 bridged, then it should be bridged on the stacked chip. Copper wire is fine. |
#63 | |
Hi ,i stacked two PCM 56 with a 720 ohms common I/V resistor , without any major problem and a good result . Later I implemented a common MSB adjustment circuit (except the 470k on trim 15) . Maybe it's not an ideal solution , but it workx quite well . |
#64 | |
sorry for late jumping in. Is there any recommended value and/or brand for capacitors in this app? Kind regards, Stefano |
#65 | |
do you mean to have separate I/V stages for each paralelled DAC and "combine" them (I imagine adding them), or what? Stefano |
| CS8412CP, DF1704E, PCM1704UK, PCM63PK SM5842AP/APT etc | xaudiox | Vendor's Bazaar | 7 | 23rd December 2008 12:31 PM |
| PHILIPS I2S to PCM63PK | robo | Digital Source | 8 | 4th October 2008 07:49 AM |
| piggy-back op-amps | amc32 | Car Audio | 6 | 14th July 2008 08:48 AM |
| TDA1545 – possible to piggy back? | jnewbold | Digital Line Level | 17 | 19th December 2007 05:47 PM |
| parasound dac 1500 piggy back | jamone | Digital Source | 0 | 19th February 2006 02:48 PM |
| Page generated in 0.08250 seconds (72.40% PHP - 27.60% MySQL) with 11 queries |
