Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th May 2005, 11:25 AM   #41
Default Re: Go, Bernhard, go
Originally posted by carlosfm
Let the guy play, it's fun.
He will eventually make a revolutionaty design with a pre-historic chip...
Just the thing to go with KBK's revolutionary clock, I suppose.
Old 13th May 2005, 02:05 PM   #42
ljordan is offline ljordan  United States
Default rudi
Do you think this stacking would work as well with a more modern DAC with voltage out?
See:
tpa6120a2 headphone amplifier
I am so pleased with the sound now.
Its an akm4383 DAC.
I would try a 2-4k matched resis. on each v output?
Then connect all the other pins together?
What do you think?
Lewis
Old 13th May 2005, 02:19 PM   #43
jdunham is offline jdunham  United Kingdom
rudi
What type of I/V does you DAC use? Presumably if it was passive, you'd have to change the resistor value?
Jonathan
Old 13th May 2005, 02:58 PM   #44
Default no iv
Differential voltage out (ala Crystal). An AKM4383 dac in a Sony dvp-ns900v.
Lewis
Old 13th May 2005, 08:22 PM   #45
Originally posted by jdunham
rudi
Jonathan
Hi Jonathan.
I am still using the standard passive onboard I/V and i haven't changed anything else, just added the chips
Old 14th May 2005, 04:03 AM   #46
Default Anyone there??
fumihiko:
What do you think about stacking a DAC like akm with diff. voltage out?
Lewis
Old 14th May 2005, 03:24 PM   #47
fumihiko's Avatar
There is an effect in making DELTA SIGMA DAC parallel.
The voltage output can be easily summing up by the resistance.
if 4 paralling up voltage output DA chips
load-resistance in 1/4 of the specified value
To protect, it makes a low-resistance (47ohms to 100ohms)series in each DAC chips.
summing point is a load-resistance
a loss by the resistance but the effect which depends in parallel exceeds.
it's my latest project, 4paralled CS4340 with resistance summing up
and 4paralled CS4331 test head
Old 15th May 2005, 12:05 AM   #48
Default fumihiko
So you you think the stacking of the single ended cs chips will work?
I don't see a pdf on there website for the 4330.
Here is what I am trying to stack:
3 images, from the akm4383pdf
first one:
Old 15th May 2005, 12:07 AM   #49
second: pinouts
Old 15th May 2005, 12:08 AM   #50
third:
pin names
CS8412CP, DF1704E, PCM1704UK, PCM63PK SM5842AP/APT etc xaudiox Vendor's Bazaar 7 23rd December 2008 11:31 AM
PHILIPS I2S to PCM63PK robo Digital Source 8 4th October 2008 06:49 AM
piggy-back op-amps amc32 Car Audio 6 14th July 2008 07:48 AM
TDA1545 – possible to piggy back? jnewbold Digital Line Level 17 19th December 2007 04:47 PM
parasound dac 1500 piggy back jamone Digital Source 0 19th February 2006 01:48 PM
Page generated in 0.10235 seconds (79.63% PHP - 20.37% MySQL) with 11 queries
