Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th February 2005, 02:34 PM   #11
AnthonyAsh's Avatar
Originally posted by Dr.H
Fumihiko san, Konnichiwa
Thanks for the interesting response! I am not sure which capacitor you refer to.
Pin 1 is the servo decouple
Pin 3 is the reference decouple
Pin 4 is the Offset decouple
Pin 9 is the Rfeedback pin
Pin 10 is connected to pin 9
Pin 23 is the "Upper B2 ADJ" pin
Pin 24 is the "lower B2 ADJ" pin
Pin 25 is "potentiometer voltage" pin
Of these pins, 23, 24, 1, 3 and 4 are decoupled to ground through caps, so I would assume you are refering to these capacitors?
What do you do with pin 9 and 10 which appear to be used by the analog outputs stage op-amps? Do you connect them to your IV stage? If so they are effectively in parallel with the existing DAC.
Thanks for your input, domoarrigoto
Ryan
Dear Mr.Fumihiko san, Konnichiwa
Do you have a diagramm?
Sincerely,A
Sleep of sanity create monsters
Old 8th February 2005, 02:45 PM   #12
fumihiko's Avatar
is it?
http://www.alldatasheet.com/datashee...OWN/PCM63.html
Old 8th February 2005, 02:55 PM   #13
AnthonyAsh's Avatar
Originally posted by fumihiko
is it?
Not datasheet,but schematics of how you connected 2 pcm63 toghether.
Old 8th February 2005, 06:01 PM   #14
Bernhard's Avatar
It is easy, parallel means connect Iout together.
And digital lines.
And grounds.
And supply rails. Or give one extra supply each chip.
But not individual (decoupling) pins.
This is why TDA1541 can not be stacked. Lots of individual decoupling pins. All must be placed on the pcb.
TDA1543 can be stacked. Very simple "tcheap".
Old 9th February 2005, 04:16 AM   #15
fumihiko's Avatar
AnthonyAsh san KONNICHIWA
my piggy back PCM63 and NJM2114
Old 9th February 2005, 07:10 AM   #16
Fumihiko san Konnichiwa
Thanks for the pictures. Just a couple of questions:
1. Did you connect Pin 5 of the upper and lower chips together, i.e. are they in parallel like pin 18?
2. Did you connect Pin 1 to the -V supply via its own independant capacitor?
Finally, vs the single chip, what are the sonic benefits of going with the parallel setup?
Ryan
Old 9th February 2005, 12:30 PM   #17
fumihiko's Avatar
Dear Dr.H san
pin5,6,7,11,12,13,18,20,21,28 connected upper and lower.
pin1 to -V supply via own independent capacitor.
pin3 and 4, via own independent capacitor
Old 9th February 2005, 12:44 PM   #18
Fumihiko san,
Thanks! What would you describe as the benefits of using the parallel chips vs just using one chip?
I will try the mod sometime in the near future and post my results here. Thanks for your input!
Ryan
Old 9th February 2005, 12:54 PM   #19
AnthonyAsh's Avatar
Fumihiko san,
Ryan
Dear Mr. Fumihiko,
For me is also very interesting what you gain when you used your pcm63 config?
Old 10th February 2005, 02:57 PM   #20
fumihiko's Avatar
Dear
what a difference ,single DAC and multiple DAC?
single use , it is thin sound
dual , what a different?
triple , good sound!
quad , I was surprised
8 paralelled , had been moved!
I heard and compared, accuphase DC-91
just a little difference.
I think,best solution is 4 to 8 paralleled DAC
actually, accuphase paralleled 4 to 8.
now I try 4 paralled CS4334
CS8412CP, DF1704E, PCM1704UK, PCM63PK SM5842AP/APT etc xaudiox Vendor's Bazaar 7 23rd December 2008 12:31 PM
PHILIPS I2S to PCM63PK robo Digital Source 8 4th October 2008 07:49 AM
piggy-back op-amps amc32 Car Audio 6 14th July 2008 08:48 AM
TDA1545 – possible to piggy back? jnewbold Digital Line Level 17 19th December 2007 05:47 PM
parasound dac 1500 piggy back jamone Digital Source 0 19th February 2006 02:48 PM
Page generated in 0.13336 seconds (83.88% PHP - 16.12% MySQL) with 11 queries
