| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
I have not done a PIC project recently. I am interested in what PIC environments people use. I have done pic start pro / assembly, css c over a boot loader.
In particular, the next project I want to use a smd that will operate at 3.3v, connected to devices that are not 5v tolerant. Being able to load and reload while the pic is soldered down is critical. I would greatly prefer not to use assembly. Any suggestions? I really doubt I am the first one here to deal with this issue. Thanks! |
#12 |
If you can live with ICprog, you can embed the PIC Key circuit into your board and program in-circuit that way, but it's not a very good solution. However that's the only in-circuit method I've tried so far. Microchip has an in-circuit programming system, but I believe it only works with certain chips. That's just one of the many reasons I like the AVR microcontrollers more than PICs: its very easy to get an in-circuit programming setup going.
#13 |
The PIC KEY cct is interesting, solving the iffy ground-shift of the
original JDM / Ludi with a charge pump. surprised I had not run across it before, glad to get the link. I think: the older your OS/ the older your motherboard/ the more likely the JDM ludipipo and ICProg will work. I never had a problem with win98 and BX (p2-p3) motherboard. wisp628 programmer is also a good choice, but you gotta program the pic in the programmer.... YMMV D
intentionally blank |
| Up to date PIC programming | TroelsM | Everything Else | 4 | 6th May 2009 09:54 PM |
| microcontroller programming | traf | Digital Source | 7 | 12th September 2007 01:49 PM |
| C Programming problem | FuriousD | The Lounge | 1 | 1st December 2005 10:38 PM |
| PIC programming | future | Parts | 33 | 4th June 2003 05:26 AM |
| Page generated in 0.06766 seconds (68.34% PHP - 31.66% MySQL) with 10 queries |
