Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th February 2005, 11:21 AM   #1
sparkle's Avatar
Question cs8412 clock?
I have read somewhere that performance of cs8412 could be improved if one put's external clock to it.
Could an external clock be put on pin 19 (MCK)? Should it's frequency be 256*fs (fs=44.1kHz)?
thanks in advance and best regards
daniel
Old 4th February 2005, 11:57 AM   #2
sparkle's Avatar
MCK is output of an master clock. It can't be input.... Sorry about my previous stupid q.
Still, I would like to know how and would it be possible to provide better clock for the cs8412 than his internal clock?
If not, is the only thing one can do, to play with SCK?
regards
daniel
Old 4th February 2005, 03:24 PM   #3
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
The CS8412 is a receiver; its recovers a clock from the incoming AES/SPDIF stream and spits it out... if you somehow could feed it with a clock, then the clock would have to be perfectly synchronized with the SPDIF stream.
Your options are... (in order if increasing complexity)
- improve the PLL layout of the CS8412. If there's a big 600V, inch-long exotic polypropylene capacitor on the board which is used for the loop filter, then kick whoever put it there in the face, and replace it with a proper filter built with 0603 NPO/X5R surface mount parts.
- insert a slow PLL that cleans up the clock output of the CS8412.
- insert a SRC chip to resample incoming data to a decent internal clock, while rejecting almost all of the incoming clock jitter.
- create a MCLK (not SCLK/BCK) signal internally that feeds the MCLK lines of the stuff inside your DAC; disconnect the clock output from the CS8412. Then somehow get that MCLK signal over to your CD player so that it produces data at exactly the correct rate.
Old 5th February 2005, 07:56 AM   #4
sparkle's Avatar
hi, gmarsh
a) i have multilayer smd cap in my filter loop (cap and res in series and paralleled with a small cap- like in nonoz II I belive)
b) inserting a slow PLL would be on SCK output pin I guess?
c) inserting SRC chip - You meen something like using RS232 signal receiver ua9637 or similar and throwing it into some nand gates (like 7400) and then in CS8412 (do You have any chips in mind instead of ua9637)
d) to complex
best regards
daniel
Old 6th February 2005, 02:04 AM   #5
gmarsh's Avatar
Originally posted by sparkle
hi, gmarsh
d) to complex
best regards
daniel
b) slow pll means feeding the RMCK signal into a 1:1 PLL, with a low-jitter oscillator (eg a VCXO) and a low loop bandwidth.
c) SRC chip means something like an Analog Devices AD189x or a TI/BB SRC419x chip.
correction from earlier, (c) is less difficult than (b)
Old 6th February 2005, 08:04 AM   #6
sparkle's Avatar
Thanks - I think I will concentrate on C) for now- digital is not my thing so I will be free to ask q's when they come
thanks for replies
daniel
FS: TDA1541 S2, TDA1541A, TDA1543, CS8412, Tent Low Jitter Clock 16.9344 & 45.1584 Zodiac Swap Meet 3 21st February 2008 08:43 AM
About the clock on CS8412 to SM5842? masonlin119 Digital Source 13 10th August 2005 07:54 PM
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
Elso clock KC-7 for Dac TDA1543 with CS8412 bsyyu Digital Source 3 10th August 2003 06:28 PM
Page generated in 0.09134 seconds (75.93% PHP - 24.07% MySQL) with 10 queries
