Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st February 2005, 04:39 PM   #1
simonv is offline simonv  Taiwan
Default CDpro2 I2S For Alchemy Pro32 and DAC 3.0
I got the alchemy pinout and try to connect I2S with CDPro2, but it don't work with Pro32 and DAC 3.0, I check the pinout and signal, I confirm the I2S connect is correct, I think the problem happened on two pin, one is serial clock, the other is Master clock.
1. Alchemy Serial Clock is 2.822Mhz, it means the data is 32 bits per channel(44.1 khz x 32x2), but CDpro2 Serial Clock is 2.12Mhz, it means the data is 24 bits per channel(44.1 khz x 24x2).
2. Alchemy Master clock is 11.29 Mhz(256 FS), but I don't connect Master clock to Alchemy.
Does anyone can give me some suggestion?
CdPro2 with tentlabs XO3 MacMic Digital Source 1 30th January 2008 06:36 AM
FS: ARC LS-3B & AA DTI-Pro32 jrsun Swap Meet 0 23rd September 2005 06:49 PM
can CDPro2 reclock with Big Ben ackcheng Digital Source 5 28th August 2004 08:57 PM
CDPRO2- do you just add PS? lgreen Digital Source 7 24th February 2004 09:48 AM
EIJ on CDPRO2 DonJuan Digital Source 8 17th February 2004 04:09 AM
Page generated in 0.04588 seconds (78.34% PHP - 21.66% MySQL) with 10 queries
