| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've had this player die on me for the 3rd time (previous times under warranty). Now I have to fix it myself. Does anybody know why the PS constantly blows? Any schematics available?
#2 |
I'm not familiar with that model, as it wasn't sold with that number in the US. Please look on the PS PCB and see if there is an assembly number such as "VWR1353" or similar.
#3 |
Hi there Bud
I also have a Pioneer DV 355. I would be happy to help by measuring voltages on the power supply or checking component values for you. By the way, I upgraded my player and it sounds much better now. Dirk |
#4 |
I also have the DV355 DVD Player - My PSU has also gone on the thing - I contacted Tedelex in JHB, they have PSUs for R225 excl. VAT. I think though it is the switching IC that is gone on my one - MIP2E5DMY, which I can't seem to get hold of. They only have the lower rated ones with the panasonic agents. My PSU in my DV Player is made by Tamura. There is no VWR number on it, although when I spoke to the agents they gave me the following part number VWR 1364 - is this the correct PSU number. My PSU has the following numbers on:
KY033H Anyway are you able to clarify that the part number given above - VWR 1364 is the correct PSU for the player ? By the way - my DVD player was struck by lightning - thats the only reason it went. I can see a very small spark mark on the underside of the PCB close to the AC inlet on the "spikes". Tested all the fuses and diodes - therefore presume the Switcher has gone. The PSU is designed very badly - they should have included a ground to earth - if I get a new PSU - I will connect ground to the Chasis and the 3 prong plug. |
#5 |
From a Pioneer Service Bulletin that covers the VWR1364 power supply unit:
SYMPTOM -- No Power CAUSE -- Resistor R74 on the power supply unit is opened. (R74 may have received voltage which is more than the resistor’s voltage rating spec, and this could cause R74 to have an electric corrosion damage. SERVICE -- After confirming that R74 is open, replace the power supply unit with the new unit. REMEDY -- (On the new unit, R74 is changed from “carbon type” to “metal film type” which will not have the electric corrosion damage.) NOTE -- When the power supply unit becomes defective due to R74 open, other component parts on the power supply unit could also be damaged. Therefore, it is necessary to replace the unit with the new unit. |
#6 |
I have this Pioneer DVD player and R 74 was open on the PS. I replaced R 74 with a 1/2 watt resistor without doing anything else and the machine came up and is performing as it should. Must be lucky
#7 |
Service manual setion covering the DV-355 power supply (this is all I have)
#8 |
says file is too large. It is only 442K. Post your email and I'll send it to you.
#9 |
Hi computeruser.
Can you email me the service manual please for the Pioneer DV-355 DVD player. I have the same problem whereby it doesnt wanna turn on. I suspect a power surge in my area to be the cause. Thanks heaps!
#10 |
Hi Computeruser
If you can post the file to buddyfriend850@hotmail.com that would be great! Thanks!!!
| pioneer SA-6500 II problem | udip | Solid State | 9 | 11th March 2011 10:06 AM |
| Pioneer SX-838 problem | b17man | Solid State | 2 | 13th May 2009 11:57 AM |
| Problem with Pioneer SA 9800 | benderski | Solid State | 2 | 15th September 2008 03:11 AM |
| Pioneer PL-200 Problem | tuwhitt | Analogue Source | 1 | 12th September 2007 07:24 PM |
| Pioneer CD Player Problem | Noak | Digital Source | 2 | 4th September 2005 04:30 AM |
| Page generated in 0.11004 seconds (78.24% PHP - 21.76% MySQL) with 10 queries |
