Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
how is it measuring?
Old 18th January 2005, 07:30 AM   #1
fumihiko is offline fumihiko  Japan
fumihiko's Avatar
Default how is it measuring?
MINASAN KONNICHIWA
my measuring ,play test CD and am measuring a spot with the distortion-analyzer.
It is only 1KHz and 10KHz.
I can not buy the AP and RS.
:bawling:
Old 18th January 2005, 12:14 PM   #2
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Default Re: how is it measuring?
Ebay spectrum analyzer can find for cheaper.
Old 18th January 2005, 03:33 PM   #3
banana is offline banana  Hong Kong
I suggest RMAA and a decent soundcard, such as "ESI Wave Terminal 192X" or "Echo MIA".
Old 18th January 2005, 04:00 PM   #4
Bernhard's Avatar
I am afraid a soundcard is limited to 20kHz ???
Old 18th January 2005, 04:27 PM   #5
fumihiko's Avatar
KONNICHIWA banana SAN
I tried RMAA wirh Roland UA-30 but,can not measuring DAC
It measured the performance of ADC
To measure surely, the performance of ADC becomes a problem.
thanks
Old 19th January 2005, 12:27 AM   #6
Bernhard's Avatar
If you like to measure 0dB signal you will have big problem because distortion is very low and maybe souncard is worse.
If you use standalone analyzer you need one with 100dB dynamics which cost $$$$$
Better use -60dB signal from Pedja`s website.
I have Nicolet 446B with only 75dB dynamics and works fine.
http://www.diyaudio.com/forums/showt...threadid=49778
Old 19th January 2005, 08:23 AM   #7
Jocko Homo is offline Jocko Homo  United States
Banned
A -60 dB test tone will tell you a lot more about your DAC than a 0 dB tone.
Jocko
Old 19th January 2005, 09:28 AM   #8
I don't have very good experience with stand alone Dynamic Signal Analyzer, the oldish HP analyzer in my work place seems to have too high noise floor.
But I have good results working with HP8903B analyzer. Though no FFT feature, its low noise preamp allow me to see -90dBFS signal. Below is the -90dBFS signal from my diy AD1853 DAC, 30KHz bandwidth, ignore vertical scale.
And I'm planning to build a diy low noise preamp and a 30KHz LPF, so that I can skip the 8903.
Old 19th January 2005, 01:17 PM   #9
Bernhard's Avatar
HI Banana,
this looks like only last two bits are switching.
Measuring such a signal is useless, exept maybe for MSB adjustment, but not to see the result.
-60 dB is better.
Old 19th January 2005, 02:28 PM   #10
fumihiko's Avatar
KONNICHIWA Bernhard SAN
I try again measurement with +20dB amplifier and Roland UA-30.
-60dB 997Hz sin-wave 16bit/44.1KHz input,
It is a result of measurement.
The vertical scale,please subtract 20dB.
The result of measurement is very good.
how is it measuring?Hide this!Advertise here!
measuring hum woodturner-fran Tubes / Valves 16 7th February 2007 03:28 AM
RTA measuring with DEQ sqlkev Multi-Way 0 7th July 2006 05:24 AM
Measuring car amp sq_guy Car Audio 6 12th July 2005 12:56 PM
Measuring Le thatvan Multi-Way 6 29th October 2004 11:09 PM
Measuring fT and hFE? capslock Solid State 6 23rd September 2003 04:50 PM
