| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 | |
I know Zobels only from loudspeaker crossovers, sorry.... Could you please elaborate a bit in this digital context? We are talking about the "Simplest TTL to S/PDIF coax interface" in the ePanorama listing, right? That one is identical to the one I stumbled across spending hours reading numorous S/PDIF threads on this forum. That's the one i implemented in my Philips transport and later in the Studer...... How does this look like with Zobel? BTW your postings were the main reason to keep on reading. Funny, and very educating for an amateur like me. Lourens |
#42 | |
Don't tell me the line driver is a D flip-flop too It's one of those puzzles I encounter studying different versions of S/PDIF circuits. The CDD882 transport uses 74LS08 as a buffer. The nearly identical CD880 (CDP-version) 74HC74.... The logic diagrams in the datasheets of those D flip-flops look quite different in my (laymans) eyes, compared to the one I found of the AM26LS31C. As i wrote before, I intend to feed it with some nice shunt food; will that do any good? But I can pull it out or replace it easily (IC's are not soldered in the Studer) if that cures the patient ![]() Lourens |
#43 |
Banned
Zobel networks.........
They work the same way here. It cancels out the leakage inductance of the transformer, to make the source look resistive. On that subject........do not use the 2:1 (or 1:2) versions. Yeah, I know Scientific Conversions tells us how good theirs are............. Ask them how low their leakage inductance is. Guess what: they won't tell you. Hard to make a zobel without knowing that. So, you have to improvise ways of measuring it. Jocko |
#44 | |||
The Transport the Theta Data Basic II, Philips CDM9 pro on a little Philips PCB to do motor and swing arm servo functions but everything else is done on a Theta designed/made PCB but full of Philips chips. Quote:
#45 | |
Reclock the DAC inputs at 28MHz? |
#46 | |
In some cases I preferred AES3 (for instance between Levinson’s 390S -- 360S) in other cases S/PDIF (Studer A727 -- Weiss Medea). Both top of the bill combinations, up till now only outdone when the transport could be slaved (like my A727 -- dCS ) in which case the interface (=format+cable quality) really becomes secondary, IMHO.Controlling the transport word clock from the DAC means you tackle one of the key problems with S/PDIF (and AES3, which is essentially the same format) in a much more fundamental way. Read this interesting TNT crash course and you know what I mean. Synchronising word clocks has a far greater impact than switching from S/PDIF to AES3, in my experience..... Lourens |
#47 | |
How about those other things, improving the "Simplest TTL to S/PDIF coax interface" aka "your recipe", and reducing jitter on the A727 dig out, if any ..... You made me curious, and want to learn! Lourens |
#48 | |
Anyway this is off topic now...... The discussions have been good and informative. |
#49 | |
PS I'll send you a pm as soon as i scanned the Paul Miller article on jitter busters! Good luck, Lourens |
| ESI Juli@Vista32/64 - no digital input ( coax spdif ) ? | ghg | Everything Else | 0 | 22nd November 2008 01:01 PM |
| Modify HK CDP to output i2s and coax spdif? | jazzzman | Digital Source | 6 | 10th January 2006 10:47 PM |
| SPDIF coax digital output topologies | Vinnie R. | Digital Source | 27 | 27th January 2004 12:42 PM |
| Coax output circuit (SPDIF) | Vinnie R. | Digital Source | 1 | 10th June 2003 04:20 PM |
| DIGI balanced AES/EBU -> SPDIF Coax | meta | Digital Source | 3 | 26th May 2003 05:51 PM |
| Page generated in 0.11814 seconds (84.39% PHP - 15.61% MySQL) with 11 queries |
