| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm looking for a good souncard to be a source for my mod DAC with ref clock output.
I'd like to have: 1) 192/24, 176.4/24, 44.1/16 output (spdif, toslink, [st, AES/EBU is good option]) able to produce unaltered digital stream 2) external 192,176,44.1 clock input 3) something cheaper then Lynx AES16 . 4) ASIO to bypass Windows directsound subsystem Two channels is enough. I don't care about onboard DAC/ADC So far I've found 2 soundcards: ESI Juli@ and Audiophile 192. What is better? |
#2 |
Two more: ESI waveterminal 192L / ESI waveterminal 192X + MI/ODI/O card
#3 |
[QUOTE]Originally posted by stolbovoy
[B]I'm looking for a good souncard to be a source for my mod DAC with ref clock output. I'd like to have: 1) 192/24, 176.4/24, 44.1/16 output (spdif, toslink, [st, AES/EBU is good option]) able to produce unaltered digital stream 2) external 192,176,44.1 clock input 3) something cheaper then Lynx AES16 . 4) ASIO to bypass Windows directsound subsystem Two channels is enough. I don't care about onboard DAC/ADC So far I've found 2 soundcards: ------------------------------------------------------------------------------------ You can't have 192k output unless you pay a lot more! Soundcards are already too cheap and suffer in quality of electronics! |
#4 | |
Which sound cards do you reference, mentioning “lot more”? Something like Lynx AES16? I think Lynx AES16 definitely able to do what I want for ~ $700 for 16 channels with all professional bells and whistles. Ideally, I would like to have the same, but 2 channels and for less. |
#5 |
...if it ain't broke don't fix it - make it BETTER! |
#6 |
After a long time deliberating, cogitating and digesting I've decided to buy an Esi Juli to use as the interface for a PC-based scope.
It seems like a good choice - having a 24/192 input, however I am curious as to why less than half of the possible input range is being utilised? Is this because of a fixed LP filter on the input stage such that the wide selection of sample rates is accomodated (this would be my first guess)? Also (if slightly preemptive) does anyone have any experience modifying sound cards - i.e. would it be possible to redesign the input stage filter such that the full frequency range (i.e. 0Hz - Nyquist limit) be utilised? Is there a digital filtering system on the card that would make this pointless - i.e. a fixed digital LP filter after the ADC stage? Is this removable? Any thoughts welcome, especially if you own the card. Cheers all
| SPDIF from Soundcard | orangeshasta | Digital Source | 7 | 26th July 2007 05:03 AM |
| CDROM->soundcard via spdif - getting lots of distortion | percy | Digital Source | 12 | 23rd April 2006 10:41 PM |
| "audiophile soundcard" | sambou | Digital Source | 14 | 23rd November 2004 08:57 PM |
| Multichannel SPDIF soundcard? | Robin | Digital Source | 2 | 1st July 2004 03:53 PM |
| 4x SPDIF out soundcard conversion? | MWP | Digital Source | 5 | 4th February 2004 12:48 AM |
| Page generated in 0.09394 seconds (76.95% PHP - 23.05% MySQL) with 10 queries |
