| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I want to try to fix a Rotel 855 for a good friend.
I replaced the clamp on it once ten years ago and he thinks I can fix CD players, which is not true, but I wouldn't mind learning more about CD players! It is a very nice sounding player with a very respectable power supply and nice layout. Anyway, it intermittently stops in the middle of a 'track' as if the CD was finished playing. There seems to be no pattern to this and it does not happen every time. I also I hear occasional digital clicks. I cleaned the lens, but that didn't help. Would it make sense to replace the laser assembly? Thank you, Michael |
#2 |
Hello,
use the Search function for the "Rotel 855" will get alot of infos here. All the Best. Chlo |
#3 |
Mikelo: I got the service manual, if you think that it can help you. Send me an email if you need it.
//air |
#4 | |
to fix and upgrade the clamp, but I didn't see anything on this specific problem. This is not a case of skipping. Thank you 'air' and I sent an email. Michael |
| Rotel RCD 971 Carriage Problem | trombone | Digital Source | 13 | 31st August 2008 05:54 PM |
| Rotel RCC-955 Problem | sorenj07 | Digital Source | 0 | 27th February 2007 01:51 AM |
| Rotel RA-931 problem | njholland | Solid State | 3 | 16th July 2006 04:01 PM |
| Rotel amp problem | Rotellian | Solid State | 14 | 6th February 2006 05:32 PM |
| Rotel RCD965BX LE Problem | johnmarkp | Digital Source | 6 | 9th May 2004 08:29 PM |
| Page generated in 0.05948 seconds (82.92% PHP - 17.08% MySQL) with 10 queries |
