Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th January 2005, 11:10 AM   #1
Default series clock for cds - is it new?
Hello
Like Elso I am a chemist, but oposite I am weak in digital.
Please comment of a chematic of a clock that I found on some Polish site.
As I have read from a description, the oscillator is sonnected in series, not paralled like in most application.
The clock is very stable and its drift during a year was 0.
It could work as "slave" and might be steering from indepentent voltage sources or PLL.
To work as cd clock we have to ommit R5,6,7,8,C9,D1.
D1 should be replaced with a fixed capacitor.
Here is the link: http://stud.wsi.edu.pl/~sikrolb/sche...oscylator.html
regards, Pawel
Old 10th January 2005, 11:18 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
This is a series resonance oscillator. I have used this circuit (very simlilar) for a digital clock (on the wall) and the frequency was 4.194 MHz.
If you are going to use such oscillator note that the crystal must be made for this operating mode because the stability gets really bad if you tune a parallel crystal to series resonance, ie 4 MHz parallel tuned to 4 MHz series.
/Per-Anders (my first name) or P-A as my friends call me
Old 10th January 2005, 12:56 PM   #3
Bricolo is offline Bricolo  France
Bricolo's Avatar
Can you explain why stability goes bad when using a parallel crystal in series mode?
I'm reading Hans Camenzind's book (http://www.designinganalogchips.com/) and at page 158 he mentios series and parallel resonnance modes for a quartz.
He didn't precise that crystals are made or either one or the other mode, just that both are 0.2% apart.
BTW, in our (unmodded) cd players, is the classical cmos inverter/crystal combo a series or a parallel oscillator?
Mr Camenzind also proposes an optimized cmos oscillator, with a series resistance (more details about this in his great (and free!) book) has anyone tried it?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 10th January 2005, 01:22 PM   #4
This means that for my Philips CD I have to use 11,28....MHz quartz?
regards, Pawel
Old 10th January 2005, 01:23 PM   #5
... and series method realy gives more stable frq than parallel?
regards, Pawel
Old 10th January 2005, 01:51 PM   #6
peranders's Avatar
Some people claims that and the reason would be that the series resonance is sharper than the "anti resonance" when you are using the "L" part of the behavior.
Old 10th January 2005, 01:54 PM   #7
peranders's Avatar
When you tune a crystal much the Q factor will be worse (less stable oscillations) and the tuning elements will have more influence of the oscillation.
Old 10th January 2005, 01:56 PM   #8
peranders's Avatar
Most of the time the latter.
Old 10th January 2005, 02:12 PM   #9
Bricolo's Avatar
can someone show us a basic series clock and a basic parallel one? I'm not sure of the difference
Old 10th January 2005, 02:19 PM   #10
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Crystal Oscillator
Hi padamiecki,
The circuit pictured is from the Elektor magazine. It is a Buttler oscillator if I am not mistaken.. This type of oscilator has certain advantages at very high frequencies like 100MHz. I tried all kind of oscillator circuits and found the Colpits the best though the differences are not big.
I found that a FET gave better results but the circuit could be modfied so.
Per-Anders you are completely wrong. There is no fundamental difference between a series and parallel resonant crystal. The only difference is the way it is calibrated. A series resonance specified crystal will oscillate at a slightly different frequency in a parallel resonant circuit like my clock.
Looks like you never studied the papers you promised to send me a year ago but never did.......
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 8 21st September 2003 02:27 PM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
Page generated in 0.10598 seconds (80.61% PHP - 19.39% MySQL) with 10 queries
