Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st July 2002, 09:19 AM   #1
ftorres's Avatar
Default Nuts and bolts, and ground and ...caps
Hi there,
Yes, caps again I came upon a review of BelCanto's DAC2 in a french magazine. There's a nice photo of the mainboard (I'll scan it ASAP), and something puzzles me... The board is bolted on a metal plate, which acts as a shield, and separates the mainboard from the power supply and transformers (photo here), and I suppose it is connected to chassis ground. There are six screws on the mainboard, seemingly electrically connected to the bottom plate with threated mounting posts, and according to the photo on the magazine, each bolt's head seems to be connected to the PCB ground though a small SMD cap (sorry, I couldn't find a decent photograp showing these caps). And I wonder what is the exact purpose of those caps With my limited knowledge, I was assuming that chassis and digital ground connection had to be made at a single point, with plain and big wire...
I made a few searches on the web, and I couldn't manage to find something relevant (yes, H.H., even on www.sigcon.com), but perhaps I missearched
Any help/hints/link welcome...
François
"Learning French is trivial: the word for horse is cheval, and everything else follows in the same way."
Old 31st July 2002, 02:15 PM   #2
Banned
Default exact purpose of those caps
I hate to go out on a limb here without seeing the circuit up close but I will take a shot. I believe the shield is to keep RF noise out of the analog circuits. The caps would couple the sheild to the analog ground plane. It may not be desirable to let analog signal or power supply currents flow through this shield so the caps provide an increasingly high impedence as the frequencies go down from RF to audio frequencies. This allows current flow at RF frequencies but inhibits it at audio frequencies. Being that the raw supply is right below the analog circuit, one also has to consider coupling of power supply noise into the analog circuits as well. Add EMI radiation from digital noise coupling to the power supply and you yet another consideration. Anyone still thing grouding is straight forward? There have been books written on the subject and the exact approach taken depends on many variables. Think this is bad you should look at the grounding for several racks of telecom equipment with the added concern of transient current of hundreds of amps from lightning.
http://www.amazon.com/exec/obidos/AS...272109-0907141
http://www.amazon.com/exec/obidos/tg...41#reader-link
H.H.
P.S.
Everything you wanted to know about heatsinks but were afraid to ask*
* well maybe were not afraid to ask over and over on this forum!
Old 31st July 2002, 02:59 PM   #3
ftorres's Avatar
Harry, thanks for replying and for references... and I didn't mean that grounding was straightforward
Sorry about that, I'll scan it tomorrow. I've tried to explain the setup the best I can, but I surely have missed some points.
I also thought that it has something to do with analog vs digital ground, but the capacitors/bolts duets are also present at the bolts located near the analog section... where a high impedance device (ferrite beads) should have been more efficient to cut down RF noise coming from the shielding/grounding plate... But as usual, I talk without knowing
In the meantime, I found a post by Goudreau that says the same kind of things, but I keep on searching...
François
Old 31st July 2002, 03:45 PM   #4
tiroth is offline tiroth  United States
There is a grounding scheme presented on sigcon that seems similar; a large metal sheet connected to chassis ground (presenting extremely low impedance) is bonded to the PCB at many points. This was a brute-force approach to ground contamination in mixed-signal boards. It wasn't really recommended, but was presented as a potential solution for non-ideal setups.
If you aren't familiar with this I can dig the link up at lunchtime.
Old 31st July 2002, 03:50 PM   #5
ftorres's Avatar
Hi Tiroth,
Yes, would be fine to have the link, since my browser (Netscape 4.7x/Linux) doesn't feel comfortable with the new Sigcon's site layout (weird tables )
Thanks,
François
Old 31st July 2002, 03:52 PM   #6
Banned
Default Ground references
I used to work with Pete and he is an RF Guru. You should see some of the papers on digital decoupling he has written. Unfortunately they are proprietary to Alcatel. Check out your local technical bookstore for some on the references. I have read most of them and they are very good.
H.H.
Old 31st July 2002, 04:03 PM   #7
Here you go:
http://www.sigcon.com/Pubs/edn/multipleadc.htm
At least everything is in one place now (?) I think...
I never understood why there were two sets of articles that weren't cross-referenced.
Old 31st July 2002, 04:10 PM   #8
ftorres's Avatar
How fast !
Thanks for the link. I found it once, but I'll reread it carefully.
François
Old 1st August 2002, 01:55 PM   #9
ftorres's Avatar
Default Here are the scans
The mainboard, with the six bolts/caps... Sorry about the quality, but it had to fit here...
François
Old 1st August 2002, 01:57 PM   #10
ftorres's Avatar
And a closeup on one bolt/cap... One via on the left, track going to the cap, and a track from cap to screw. Still searching...
Tiroth, the link you provide has calrified some points, but the caps are not mentionned
François
values of ground(?) coupling caps in Aikido cbutterworth Tubes / Valves 1 31st October 2007 03:53 PM
ASC metal can polypro caps: ground the metal can to AC ground? jarthel Tubes / Valves 10 6th September 2006 12:54 PM
Tiny Nuts and Bolts PHilgeman The Lounge 3 24th May 2004 04:55 PM
I'm going nuts over these bolts Hefty Multi-Way 8 24th December 2003 10:06 PM
Nuts and bolts for binding posts Vikash Multi-Way 15 31st October 2003 08:04 PM
Copyright ©1999-2013 diyAudio
