| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'd like to build a DAC from TI samples, but I'd like to know which chip should I use(For 44.1 or maybe 48k).
Antoine http://dmsaudio.ca/ |
#2 |
Banned
They are pushing the '1792 series. I have also heard that they aren't generous on this one. Who knows............
Jocko |
#3 |
I guess I'll have to spend 20$ on a PCM1702, or if there are good ones in the PCM179x (Except the 2, which you wrote about)
Or if there are no good samples, I'll go with TDAs.
#4 |
Banned
Didn't say that there were "no good" samples. The TI rep gave me dozens of '1738s......which I never tried, but was coy when I mentioned the '1792s.
At one time, they weren't making '1704s, and I had projects that used them. Supposedly, they wanted guys like me to stop using them. Then the '1792s started to get tight, and '1704s became available again. I have no idea what they are up to, but knowing TI, nothing would surprise me. Too bad they had to "rescue" Burr-Brown. It will only be a matter of time before they make it as screwed up as the rest of TI, and it vanishes. $20 is cheap........look at the '1704.......AD1862. The '179x series uses a much easier to fab process. It should be around for a while, once they figure out what they want to do with it. I would recommend looking at that series. Just don't expect them to gladly throw some at you. They may......who knows. Jocko |
#5 |
For any semiconductor company, availability seems inversely
proportional to the goodness of the economy. Right now, you should have good availability for most things...
bel |
#6 |
Only the 179x are avail. as samples.
I think I'll go with the TDAs(4-5$ each) if I don't get samples.
| TI Samples | ctardi | Parts | 22 | 12th May 2010 07:41 PM |
| what the (&*%&^%&*)^*10 samples? | karma | Chip Amps | 46 | 1st June 2004 06:42 PM |
| Samples | costiss | Parts | 21 | 9th November 2003 12:14 AM |
| Op-amp samples | Optical | Solid State | 12 | 14th November 2002 10:43 PM |
| Page generated in 0.08402 seconds (76.94% PHP - 23.06% MySQL) with 10 queries |
