Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th January 2005, 02:08 PM   #1
Bernhard's Avatar
Cool DAC directly drives headphones & speakers ?
Is this possible ?
Maybe somebody already is working on it, over the hills and far away
Old 7th January 2005, 02:49 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
DAC chips by themselves, at least the ones I'm used to, doesn't have the output drive capability to drive a speaker or headphone.
As for DAC *boxes* by themselves, they might... it all depends on your definition of a DAC, and my own definition is a box which has digital input and line level out.
So lets say you put a higher power amplifier (headphone, speaker, whatever) inside a DAC box. You'll obviously then need a volume control, the ability to switch between different inputs would be nice.. and finally if you keep adding features you eventually end up with something that isn't a DAC by my definition but rather something closer to a home theatre receiver.
So, what's a DAC?
Old 7th January 2005, 05:28 PM   #3
Its been done before use the Search engine.
Old 7th January 2005, 06:13 PM   #4
Bernhard's Avatar
This thread ?
"totally ridiculous digital amplifier (power DAC) idea"
http://www.diyaudio.com/forums/showt...ht=#post343185
Old 7th January 2005, 07:51 PM   #5
I have made a DAC that directly drives headphones. See 16 x TDA1543 DAC directly drives headphones
for details.
This project was completed over a year ago and has been in continuous use since. It's been very worthwhile as filterless direct drive makes a real improvement in the sound.
However, this design only really works with Sennheiser HD25 phones (70 ohm and very high sensitivity). I'm working on a 20 TDA1543 version with higher power supply voltages which should be compatible with a wider range of headphones - I'll report back when it is completed.
Enjoy!
Old 8th January 2005, 02:57 PM   #6
Bernhard's Avatar
I think about a DAC that delivers something between 1W and 100W.
Multibit and without I/V conversion.
Old 8th January 2005, 04:21 PM   #7
Why don't you give us a practical implementation?
Old 8th January 2005, 04:44 PM   #8
pburke is offline pburke  Germany
Default Re: DAC directly drives headphones & speakers ?
Is this possible ?
I'm working on a DAC that will hopefully drive headphones directly. A 16-way paralleled DDDAC1543. I'll know in a few days what it'll do to a set of regular Sony MDR-V6s. After that I'll try some more difficult to drive headsets.
I'm driving these TDA1543s at 8.5V so there will be a lot more juice coming from them than in the other unit linked above. How much better it'll be I don't know until trying it.
Peter
Old 8th January 2005, 05:01 PM   #9
Bernhard's Avatar
This sounds cynical.
Old 8th January 2005, 05:25 PM   #10
That sounds like an excuse
Pregnancy headphones/ speakers? lgreen Multi-Way 3 30th December 2008 12:00 PM
can i wire an ipod directly to car speakers w/o reciever? james57 Car Audio 3 25th December 2005 07:44 AM
16 x TDA1543 DAC directly drives headphones Intermod Digital Source 3 7th September 2004 10:09 PM
headphones that sound like speakers Xray Everything Else 6 14th October 2003 01:13 PM
Switching off speakers when plugging in headphones? Christian Everything Else 20 28th August 2002 09:35 PM
Page generated in 0.10848 seconds (79.98% PHP - 20.02% MySQL) with 11 queries
