| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#31 |
Hi all,
I have read all this thread, and is informative. I have similar problem with my Onkyo DX6870 aka DX-708. While the disc is spinning for some seconds, the disc is waving a lot and after some time it stops. It seems that problem is with spindle motor. thanks bekim |
#32 |
I own also a DX706 since several years and have the same problems as described here.
I already tried to clean the laser lens -> no improvement I have tried to clean the guiding rail of the laser and then to lubricate it again with new oil -> no improvement I will now try the advice of david and oil the spindle motor. If it does not work, I will then try to replace this motor. Just one question to you who already did it: How have you removed the part that support the CD? The one inserted on the motor axis. Thanks in advance for your feedback. Jpierre. |
#33 |
Hi
Do you mean the plastic part which spins the cd..? That is easy: just pull it out. But careful. Did you try to adjust it according sm? bekim |
| cd onkyo integra dx706 | pecotin | Parts | 0 | 8th July 2009 02:21 PM |
| Onkyo DX 330 needs help | phhphd | Digital Source | 0 | 27th March 2008 03:36 PM |
| Help: Schematic for Onkyo DX706 | derekyu | Digital Source | 0 | 12th November 2007 04:06 PM |
| Onkyo M-504 needs help pls | Revenoor | Solid State | 0 | 21st October 2007 10:35 PM |
| Onkyo M 508 | beks | Solid State | 18 | 31st May 2004 07:25 AM |
| Page generated in 0.07505 seconds (72.15% PHP - 27.85% MySQL) with 10 queries |
