| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Dear all,
I need to order some TCXO for my 1541a RE-clock kit. Can anyone told me that TCXO really good in re-clock circuit because its more expensive than standard 30ppm oscillator. The best TCXO was less than <1ppm. If I choose <2ppm or <5ppm TCXO will cheaper. anyone can give me some opinions. thx thomas |
#2 | |
The ppm level is not relevant as long as it is within the redbook specification (+/- 100pm). You should look for the jitter specification. best regards |
#3 |
Dear Guido Tent,
very thanks for your advise. I try to ask the factory already. But they only produce very high precision standard TCXO, XO in very low ppm. Very low ppm & high accurancy as 1/10000% resisters for measurement equipment. lots of parts produced from this factory was gold legs. They( This Factory) did not produce any parts for audio use. As the NPC, not mainly in audio field. So they did not understand how jitter effect the sound quality. BTW, this is sample of the coming precision ~2ppm TCXO from -10~+85 stability TCXO. Hope diyers will like them. I will try to put this into my coming re-clock kit. Hope the performance will improve more. thx thomas |
#4 |
Banned
PPM is a useless parameter for audio. I don't care how low it is.
Jocko |
#5 |
Well, I don't think so.
PPM is very important to me I even use 45.1584MHz clock for my heavily modded SCD-1 by an external proffesional synthesizer. http://www.programmedtest.com/pts160.html Mine is oven controlled version, OCXO. The fellow in here uses Cecium clock. Rubidium is not good though Teac uses in their Esoteric G0-s. My choice for the best combo will be a very good (but expensive) oven controlled x-tal osc. (will costs you more than $1000) Kohjin |
#6 | |
You occasionally see Tracor Rubidium oscillators on the Bay -- not easy to fix, however. MY CD clock -- garden variety !!!!! I just listen (sorry Elso). |
#7 |
I always turned switch on the synthesizer of course, why not! Forget about Rubidium OSC we tried and confirmed not good. Kohjin |
#8 |
Dear Jocko,
Let me ask a silly question? How can get standard XO in Low jitter. I saw the factory selection for the crystal was use a equipment with XXXX.XXXXXXXXXXXXMhz to test & selection for them. Will this selection can easy choose out the low jitter one?? thx thomas |
#9 |
Banned
Well, for starters...........you need a very quiet power supply.
The circuit is important, although something as simple as a Pierce can work well. Most "standard" XOs have poor jitter, because the circuit is not optimised for that, or really anything else. Except price. High accuracy ones are optimised for accuracy. Some might spec jitter, but I doubt it. The long term drift of a crystal is mostly a function of how clean the quartz is. Jocko |
#10 |
and how do you optimize a circuit for low jitter?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
| is a resolution of 0,001 UI good to measure clock jitter ? | Bernhard | Digital Line Level | 1 | 8th December 2008 03:01 PM |
| MK2703 PLL clock in SACD, good or no good? | tubee | Digital Source | 19 | 7th April 2007 09:04 PM |
| Where can I buy TCXO | ackcheng | Digital Source | 0 | 21st February 2005 05:04 PM |
| Tcxo | XTAL | Digital Source | 21 | 17th May 2004 02:18 AM |
| Good clock radio | eRiCdWoNg | Everything Else | 0 | 5th December 2003 09:21 PM |
| Page generated in 0.10333 seconds (87.78% PHP - 12.22% MySQL) with 11 queries |
